After 1 Month of research I think im ready to order
This build will be used for gaming streaming recording and editing.
Thanks for checking it out and tell me if you think i did something wrong.
http://de.pcpartpicker.com/p/3mVK7
I don't really like the Corsair CX series. That's a personal thing. I would prefer this http://de.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
Why is that ? And what do you think about the rest ?
I can't speak for Shadre, but I don't like the CX's either. Mostly cuz they are overpriced for an 80+ bronze psu. Cables are a little funky as well, flat, ribbon style 4 pin CPU power a la a SATA power cable makes for some tricky cable managment.
Please do yourself a favor and find a good 80+ Gold PSU. Seems like every time I necromancer someones PC it's because they decided to skimp on the power supply. Power stability is a huge factor in both the stability and lifetime of your build. So it should be that last place to cut corners on price.
I have been building systems for 10+ years and I have never had one go full retard because I always put in a better quality PSU than the rest of the system. It is just good insurance.
If you can live with an extra ~20 euros then I would strongly recommend http://de.pcpartpicker.com/part/xfx-power-supply-p1550bbefx. Best price for a Gold in a good brand on that site.
As for the rest, The Samsung 840 EVO stomps all over the crucial in "bang for the buck"
http://de.pcpartpicker.com/part/samsung-internal-hard-drive-mz7te250bw
And while some people say the opposite of me I will recommend WD over Seagate anytime. I used to love Seagate but their quality has dropped dramatically in recent years. Bought the same drive listed here a while ago and it and the 2 replacements afterwards died catastophically within a couple months. so...
or if you want cheaper and are ok with not super speed on your giant HDD
http://de.pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezrx
 All this is purely opinion and preference and I realize just about everything I have suggested costs more. But you really do get what you pay for and IMHO it is better to do without then pay a little less for a product that is not as good a deal.
The CX series is Corsair's lowest spec series. It'll probably be ok, but that series has a higher failure rate than the rest of their PSU lines. The XFX has a great reputation and is a higher quality PSU for just a few Euro more.
+1 to those recommendations. The PSU might be a little overkill, but the logic behind the decision is sound. Shadre's recommendation is sufficient if you don't want to spend that much.
Also, I think the links got mixed up for the HDD. The first one leads to the Samsung SSD again. A Western Digital Black series hard drive has a much better reputation than the Seagate drives.
Looks pretty solid. Corsair actually got some cheap Gold certified psus. I'm using a Corsair CS750M and it's rock solid. Also if you going to do crossfire later i would suggest buying the CS750M. Super cool.
Im also thinking about this one:
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/330c2022052808c0c273902ceb8bc531264fcb92253e0df4b31
Would that be better ? nearly same price
They should perform about the same.
