As we all know modern GPUs are terrible in terms of space efficiency and with workstation platforms like WRX80 / WRX90 it’s basically impossible to avoid covering your precious pci-e slots if you use GPU - especially if you use more than one GPU (as single GPU often can be installed vertically on riser, saving pci-e slots).
Since I use multiple GPUs and I already ran out of pci-e slots I’m wondering what are my options now and the most appealing option seems to be external pci-e box.
I found some products but they all seem to be only pci-e gen3:
Are there any gen4 options? Preferably more reasonably priced since that costs more than my entire motherboard lmao…
They require to contact them to get a quote. It’s basically golden rule of thumb that if company requires you to get quote from them, then you can’t afford it XD
the one i see talked about is from cpayne. apparently you can use these to add loads of gpus to a system https://c-payne.com/ i’ve seen people put their motherboard on a mining frame all open and then put their gpus on risers there.
Looks very good in terms of pricing. It probably will require some tinkering with PC case to make it compatible with those seemingly not-very-ATX-compliant mounting holes but seems doable.
