Hey guys,
I need to buy 2, around 24", 1080p, 60Hz monitors. I mainly use them for gaming and some movies, and maybe some coding when I work from home from time to time. I just really need them to be wall mountable because my current ones are not, and I’m planning to buy a desk mount, and thats the only reason I’m deciding to switch them with new ones, the other is that they are different and that pisses me off sometimes.
So i was looking at this: AOC E2476VWM6
But I don’t know much about monitors, and also don’t know which brands are good. Maybe you can suggest something else, or give your opinion about this.
At work we use Dell monitors and I think they are really good, so I was looking for 2 of those, however I don’t think its worth it to spend that much money since they are about 100-150 dollars more expensive.
LG 24MP68VQ-P…
I can find it around 150€.
24" IPS 75Hz Freesync monitor.
If you put the Freesync aside, you still have 24" 75Hz IPS monitor from LG with both Display Port and HDMI connections.
I have not used any AOC monitors so I cant comment as to their quality. At home I use 3 24" LG monitors similar to this (in fact I think thats the exact one but mine were not refurb). The colors are pretty good, they are IPS, and they have vesa mounts. They match eachother pretty closely, only one is slightly off in color and thats probably due to the fact that I bought it over a year before the others and its seen some use.
In my experience the LGs offer a decent middle ground on price/quality.
if your ok with other sizes:
https://www.bestbuy.com/site/acer-refurbished-k272hl-ebid-27-led-fhd-monitor-black/5678101.p?skuId=5678101
https://www.bestbuy.com/site/acer-refurbished-h6-series-23-ips-led-hd-monitor-black/5515023.p?skuId=5515023
23 and 27 inch for 80 and 130 bucks
Yeah I’m not in the US so I probably wont be able to purchase any refurbished monitors form best buy.
Other than that I’m fine with other sizes, if its 23" or more its ok.
Dude, just get the 24" LG for 300leva from Nikem and you are set…
http://nikem-bg.net/computer-components/24-LG-24MP68VQ-P/
The others 24" and near that size are 280+, and the LG is IPS 75Hz…
PS: your account info states you have R9 290, so you can use it as freesync as well…
