Advise on deploying a homeserver
HI
I’m new here and new to Homeserver deployment and could use some advice on a few things.
First things first - Hardware:
Planning to use either my old Core I7 7700K with 32 Gigs of RAM and my GTX 1070SC. Or a Core I7 8700K (8086K) as a hardware platform.
Now I do have a spare 1080Ti but it’s a FE board that I used to watercool - but since I am not planning to water cool within this setup I’d rather use the 1070. Cuz… the blower style cooler on the FE 1080Ti is not exactly quiet.
For starters I’m thinking, OS on an SSD (SATA) and 2 x 4TB HDD for Storage - with plans on expanding.
After reading a little on the topic and watching plenty of vids with Wendel on his 2 channels, I was thinking that the platform could be ProxMox.
I’m hoping to roll out these “services” (Dockers I believe they are called) :
  1. Media server - leaning towards JellyFin
  2. File server - where, if possible, phone data could also be uploaded to instead of Big Tech cloud solutions. I have no idea what options I have on ProMox, let alone what would be good for a small, somewhat scalable, home solution.
  3. Home Assistant - Here I’m gonna take it slow cuz one can do so much. But I wanna familiarize myself with it.
  4. An Office solution of sort is also something I’m considering - again unsure of my option.
I don’t need more than 1 Gigabit network speed for now, and I know that I can always add a network card should I need more speed.
Last thing that would be a must, is Remote Access to all services.
Should be doable - right?
Oh forgot to mention: I don’t wanna base this on any Windows server of any kind. If wanted that I would just done so. But one of my ideas behind my project is to cut ties with Big Tech
Questions:
  1. Is ProxMox the best “OS” platform for a noob like me, when it come to having one machine running multiple servers/dockers given what I have in mind?
2.Do I need static IP to VPN in to the above mentioned services?
Or is my current setup with Mullvad as VPN good enough ?
After having read a little, it seems like I can tap in to an API of theirs to gain access to my home server that way, but I’m unsure on the best and easiest approach.
That’s all for now
I’ll be most grateful for any and all advise on rolling these server solutions out that you guys, women too ofc :wink: , can provide.
Thx up front and many regards
Fred
P.S.
@wendell All your content on self hosting has been a great inspiration for me going ahead with this project. So if you this a big thanks.
Also thanks to the entire PC DIY community - it’s very inspiring to be apart of it.
ok so a couple of things here from someone who has been self hosting for a bit i personally would run the 8700k. Also unless you already have a dedicated nas box your going to want to run truenas virtualized on proxmox to handle that side of things but youll need to dedicate a minimum of 16gb of ram to that leaving you with 16gb of ram for everything else and if you go that route youll need an hba but the nice part is that going this route means all of your services because they are on the same host ie jellyfin etc can access the nas instantly and use the nas to store all of the large files youll need like movies etc. Personally i would stay away from nextcloud as it tends to have lots of issues constantly and i personally just use my nas as my fileserver connected between devices. For on the go access the easiest and best way is to spin up a debian container on proxmox and install tailscale or netbird in there and set up that container as a subnet router and exit node which will give you on the go access to anything on your network provided your connected via tailscale on the client device or devices and will also encrypt your traffic while on the go if you happen to hop on public wifi etc as long as you have the tailscale container as an exit node. I would not say that proxmox is the easiest beginner solution but it is the most flexible and will let you do basically whatever you want and its personally the solution i use. You will need to set static ips on your home network through your router for all internal services though.Edit: Also for backing up photos from the phone just use immich. you can also use syncthing for backing up files across devices to the nas as well. Edit 2: You also dont need to use a dgpu at all unless your going to try to run something like frigate with home assistant as both the 7700k and 8700k have intel quick sync which is more than capable of handling immich and jellyfin transcoding for a typical household use case so this will also save you on some power consumption possibly.
Welcome to the wide world of home servers!
Proxmox is great for it’s flexibility and comprehensive approach to deployments, but I wouldn’t start there, it is a lot for first starting out.
If you are looking for an “all in one” solution, something Like TrueNAS Communitiy Edition is an easy entry OS.
The main difference in these chips is Intel Quicksync, a media transcoding hardware solution that works great in a media server, the 8th gen has it, earlier chips don’t.
You are going down the right track. I don’t think you are going to notice much between the 2 CPUs. Memory at 32GB might be a bit tight.
I like using Proxmox for what it is, a hypervisor. Also because you can snapshot a VM before upgrading or making changed and rolling back if needed. It also handles the storage RAID needs.
Under Proxmox, I run a Debian VM. This does most of the work and has most of the storage presented to it. Under that is all my docker containers. Having them on the same VM makes it easy to share information and storage between them.
Aka, Under Proxmox, the 2 HDD drives are setup in a ZFS RAID1 as a disk pool. Then for the VM, a Video drive is created for my Debian VM, and that gets mounted under /mnt/video.
Then all my docker containers and NFS access /mnt/video for video storage.
On the Debian VM:
I have 40+ docker containers organized under /srv/docker/ with their startup script or compose file and persistent storage. It’s a bit of a manual process, but I find it’s easier to maintain long term.
All the docker containers are fronted with HAProxy that handles the SSL with LetsEncrypt.
https://jellyfin.(mydomain).net → HAProxy(in docker) → Jellyfin(in docker).
https://homeassistant.(mydomain).net → HAproxy(in docker) → homeassistance(in docker).
And on and on for 40+ docker containers. 90% of them can be accessed from a web browser. It just works like any web based service.
  1. Jellyfin works great, but you may need to pass your GPU from the Host, though Proxmox, and into the Debian running the VMs for Jellyfin to use it for transcoding. Depends on how many steams you want to watch, and the source martial.
  2. For phone syncing, NextCloud for docs, and you can use a DAV server/radicale for contacts/calendar. For raw file share for Windows host, Samba on the Debian VM.
  3. You can run Home Assistant in a docker, or it does have it’s own full OS that you can run in another VM.
  4. Mostly NextCloud/OwnCloud for document storage and basic editing.
I believe you can use TailScale for your VPN needs. I use Wireguard, but I have a VPS that host the VPN server and other things connect to it. But end result is that https://jellyfin.(mydomain).net worked just fine on my phone.
