Hi everyone!
I am looking for advice on a NAS build. I would like to have a NAS at home and I have an old Dell Vostro SFF which I would like to know if its a viable option.
Specs:
- i5-3470s
- 6 GB DDR3
- 2 SATA ports + 16x PCIe (prob Gen3) + 1x PCIe
- 220W PSU
My requirements for the performance of the NAS are nothing fancy as I mainly intend it for backup purposes, no heavy workloads. I would like it to be quiet, so I was thinking about running all SSDs with TrueNAS Core. Now my questions are:
- I would split out the PCIe 16x slot into SATA ports an get splitters for the only 2 SATA power connectors the PSU has. Is this advisible? (SSDs should draw significantly less power than the HDD and DVD drive connected prior, right?)
- What’s your opinion on the Crucial BX500 2 TB as a “NAS SSD”?
- I gathered that TrueNAS likes a lot of RAM for caching purposes, but would it be necessary to get 16 GB of RAM or could I start out with less?
- There is a wifi card in a mini PCIe slot. Is there an adapter to install a small amount of storage in such a slot or the PCIe 1x slot for the OS? I don’t need the wifi.
Would this be feasible? I would like to give a purpose to this older, but working computer. I was considering starting out with 6TB (3x2TB) raw storage (raidz1, so 4TB usable) with the option of adding a second vdev later.
Any and all comments and feedback are greatly appreciated!
Cheers,
Smile
