Advice on modding a ASRock DESKMEET X300 Mini PC Barebone
i need advice on modding a ASRock DESKMEET X300 Mini PC Barebone for use as a nas / giga-switch / vm build
my plan is to add a
AMD Ryzen 5 5600G
64gb of ram
SK Hynix Gold P31 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive for main os an vm’s
2 x Seagate BarraCuda 5TB Hard Drive HDD – 2.5 Inch (ST5000LM000) to mount internal for raid back up of most vatial data of the external 20gb
QNAP QXG-2G4T-I225 Quad-Port 2.5 GbE Network Expansion Card
1 x Yottamaster Aluminum Alloy 5 Bay 2.5/3.5 inch USB3.1 Type C External Hard Drive Enclosure SABRENT USB Type-C to Dual 3.5” SATA and RAID Docking Station DS-2BCR
with 2 x Seagate IronWolf Pro 10TB (ST10000NE000)
upgrade psu to sfx an cables
add 120mm aio vi external modding
something like this
  1. whats the psu form factor an size , as id like to replace with a fully modular gold efficient psu
an custom cables by cablemods.
  1. does anyone have any tear-down pix of the inside ?
  2. does this take full size ddr4 ram
  3. has anyone run truenas core or scale
  4. does the mobo support a 5600g out-of-the-box with out firmware update
  5. can i install a pci multi port Ethernet card an run truenas with router os in a vm an config some of the ports
    as vlan’s an leave the others as just normal lan ports, is this something i can do vi router os an from a vm in truenas
Here’s what 2 seconds of Google would have found you:
https://www.asrock.com/nettop/AMD/DeskMini%20X300%20Series/index.asp
You’re welcome :slight_smile:
thats to the mini not the meet
Oops, missed that. Sorry! :face_with_open_eyes_and_hand_over_mouth:
I only looked at the Intel one. It had a standard psu and id go for a modular sff it was me as thstll fit fjne.
Intel version had 4 dimms in full height wss no problem even insanely tall memoey like oloy
in regards to the amd one has anyone run truenas core or scale
is it a safe bet that the mobo supports a 5600g out-of-the-box with out firmware update
the ports as vlan’s an leave the others as just normal lan ports, is this something i can do vi
router os or pfsense an from a vm in truenas
i want to use the
an set two of the ports as vlans an leave the other as is
also can i run in a vm the apk app Firewalla XAPK 1.51.84 by Firewalla Inc.
to control an manage my FIREWALLA GOLD ROUTER rather then from my android tablet
my goal is to make an have a one master device to serve as my
nas / media hub / specific task vm / giga-switch , rather then 4 separate devices an pair it with
with a 20in monitor an K400 Plus Wireless Touch Keyboard
is this at all doable do you think an what do you think of my suggested parts
