First time poster but, I have been lurking around Level1Techs since the Tech Syndicate days and have finally decided to seek some advice.
I need a NAS, and it has to be quiet. Since I live in a small apartment, the NAS will be only 3 meters away from my bed. Considering my noise requirement and my current modest storage capacity need of 4TB, I believe SSDs are the ideal solution.
I assume that SATA SSDs are becoming less common, while M.2 SSDs will remain popular and readily available. I plan to keep the NAS for at least 10 years, so flexibility in adding more storage is a key priority for me.
Currently, I do some amateur editing with 8-bit 1080p 60Hz footage, but I’m planning to transition to more demanding video formats (10-bit 4K 60Hz). I aim to edit full video files rather than proxies.
I have the option to purchase either the SP3 Supermicro H12SSL-i for 629 euros. Which would provide PCIe lanes capable of supporting 20+ M.2 NVMe SSDs through bifurcation. However, I’m unsure about the rest of the system configuration and would greatly appreciate advice on the following:
Should I go with TrueNAS Scale? It seems to be the default choice.
Is my assumption correct that a EPYC Rome 8-core/16-thread CPU would be sufficient?
How much RAM should I start with, and does RAM speed matter?
Is it challenging to add more RAM later due to compatibility concerns?
Is a vdev of mirrored 2x4TB SSDs a good starting point?
Would the Crucial P3 Plus 4TB Gen 4 SSD for 210 euros suit my application?
Are there affordable PCIe x16 to 4x M.2 adapters that maintain Gen 4 speeds?
Is excessive power draw from PCIe sockets something to worry about?
Would 10GbE networking be sufficient for my workflow?
Thanks in advance for any advice you can offer!
