Advice on Building a Home Server for Mixed Use (Plex, VMs, Storage)- Need Recommendations
Hey everyone,
I have been thinking about setting up a home server for a mix of tasks like running Plex for media streaming, hosting a few VMs, and general data storage. I’m relatively new to the home server scene but comfortable with tech in general. Right now, I’m not entirely sure about the best way to balance performance and budget.
Here’s what I’m aiming to do:
Plex: Probably the heaviest task, as I’d want it to handle 4K streaming for a couple of users at a time.
VMs: Ideally, I’d like to run 2-3 VMs for different personal projects and maybe some light web hosting.
Storage: Needs to be enough for media, backups, and some file sharing. Thinking somewhere in the 10TB range to start with, expandable later.
I am not sure if I should go with something like Unraid or Proxmox, or if I should just DIY it with a regular Linux server and Docker. I’ve seen builds using older Xeon processors, but not sure if that’s overkill for what I need or if something like an AMD Ryzen would be a better fit.
Questions:
Should I prioritize more cores or higher clock speeds for a setup like this?
Any recommendations on affordable motherboards that have ECC support (if ECC is even necessary)?
Storage suggestions? Thinking of going with a few NAS drives but open to other ideas.
Any potential pitfalls I should avoid when mixing media and VMs on the same server?
Looking forward to hearing your thoughts and thanks in advance for any advice.
When I was Googling for the same I came across these resources Building my first Home Server for multi use Splunk Tutorial however they are good but I want to learn more from community members of Level1Techs.
Thanks in advance. :slightly_smiling_face:
Matthi
If you DIY based on Linux+Docker you will have (to level up to) a complete understanding of the software stack. That, in general, can be very useful, but is hell for non-nerds.
If you go with something like Unraid or Proxmox you learn how to exploit the confines of these software packages imposed to manage the complexity of the Linux+docker software stack. There are guided tutorials and most things can be accomplished in a graphical user interface.
You should probably prioritize idle power consumption for your hw setup. Make sure to identify the overall performance requirements for your workload and find the hw that sucks the least - power that is.
Most home servers are mostly idle from a workload perspective or they’re ineffectively loaded with e.g. heavy transcoding tasks for video streams that get never watched (my opinion™).
Wolfgang’s youtube channel is a great resource should you agree with this opinion.
KISS principle. Start with the largest single storage device that is available to you. Learn the software side of things first and only expand storage once you have figured out if you want to continue investing in this hobby (that’s what it is).
Home servers often get born out of used desktop or server parts that no longer fulfill their original function or simply got replaced on a schedule. Few people have the funds for all new gear for this purpose.
If you have a 4TB-10TB HDD, use that for plex storage. Use a SSD (SATA or better NVMe) for anything else. It’s going to be slow, but cheap (existing).
If you need to get new storage, consider the largest SSD you can swing. 4TB consumer drives are an option (readily available), but consider 4+TB used enterprise drives as well. These will cost about the same ($/TB storage) but will generally be of superior quality and should last a lifetime of home server use. Exploring that option is quite a rabbit hole.
If you want/need to get a HDD specifically for this build you can save a lot of $$$ with a refurbished drive, but that can be risky business and only you can accept the risk. Avoid drives based on SMR technology and find CMR drives. Look at the cost of drives from a $/TB perspective. I generally buy refurbished HDDs marketed for enterprise use and have been happy with this approach.
you may be a good fit for TrueNAS Scale as the host OS. it would simplify most of your needs and a general purpose docker use might have you covered.
as mentioned, power is probably a good thing to think about for the build.
rather you use something like TrueNAS Scale, or ProxMox, i would try to seperate out the storage for media and VM/Containers. an SSD/ NVME pool for VM/Containers, and spinners for media.
this is accurate, though an odd situation.
you should build the system so that transcode streams activate as needed. a T1000 can push 9 streams and idles at next to null.
Processing grunt doesn’t mean much there if you’re not scaling it down. Get 10Gbit. Of course, if compressed enough, that doesn’t matter; but, if you want 4K, you want high bitrate. I don’t know the standards for bitrate/bandwidth for different quality option. Uncompressed takes a lot. You can pre transcode of course. Whatever, other people can help you with that part better than I can.
The old Xeons can be had stupid cheap. Like the E5 2667v2 for $15 right now.
The boards still tend to cost a bit if it’s a standard form that easily fits an ordinary DIY case. I can say from experience, that the Rosewill rise can fit a Supermicro X9DRH-7F and the intel S1600JP.
You can sometimes find the servers with those boards in them for an ok price. The intel one would require a PSU adapter and other nonsense to get add-in cards (like 10Gbit) to fit. Supermicro tends to use standard ATX PSU connections.
Here are some options from a quick search. Cheapest 1st.
My current system is a dual E5 2667v2 X9DRH-7F with a gtx980. Struggles with modern games made by lazy devs that expect you to have modern comparatively blazing fast CPUs (Palworld for example).
There’s also some nonsense with SATA raid drivers on some of these older server boards, so if you’re not going to use just 2 huge drives, probably just get a basic Ryzen system.
Also, consider how long it would take for your power bill to make that old, less efficient stuff really be a problem. Hundreds more $ now vs hundreds more over… likely quite a few years. According to a quick glance at HWInfo64, my system is probably around 150watts, running chrome and a Palworld server right now.
Forgot to mention that, just a modest modern GPU.
I talked myself into solving this problem at the beginning of this year. I’m very happy with my full-tower Unraid-on-Proxomx storage and VM server. And I’d completely not build anything like it again.
There are like 43 ways of building great, efficient, cheap, fast (not necessarily at the same time) homelab systems. You can make trade-offs and get multiple things in the same box, but it’s really not worth it unless you start going high end (maybe including purchasing used enterprise gear). You could build an awesome threadripper box with all the IO to do multiple tasks, but I don’t think that’s what either of us are talking about.
Figure out how you want to do storage. Only do storage there. You can get dirt-cheap embedded NAS motherboards like they show on ServeTheHome, you can use any old PC and put a HBA in it. You can just host off some motherboard SATA ports. Whatever. But just host drives on that box.
Get a different box for your plex hosting. This could be an old laptop, a 5 year old potato PC with integrated graphics (quicksync) or a mid-grade NVIDA card. Whatever. Load the library over the network from your storage server. Keep the transcoding separate.
For your VMs and hosting, you mainly want RAM. Again, so many options to cheaply choose from. I’m currently shopping 32gb/64gb kits for my kids old laptops so I can run Proxmox on them and keep a bunch of VMs hot withouththem falling over from running out of RAM.
Why not put all this in a single box? You can get a modern CPU/MB that should be able to do all this stuff easy. But you really can’t get it all and get it cheap at the same time. Where can you find a MB that can slot in a small GPU, a 10GB+ NIIC, and a HBA at the same time? There are, maybe, some options, but they very quickly cost more than getting three systems. And then you’d be stuck with a system where maintaining one thing means you can’t do another. I keep meaning to do a maintenance reboot to update the BIOS on mine, but I’m just chilling and watching some TV. I’d have to kill my evening entertainment and 10 other services to do that quick maintenance. If my storage, services, and media serving were in different places, I’d have more fun playing with my homelab.
So, I’m busy offloading and restructuring. I’m still really pleased with my big tall box, but other people warned me off this design while I was shopping. And I knew better. Sigh. I could have gotten three of these for what I forked out to build tall.
ps. I’m really happy with unraid for low-effort storage expandability, but you’ll need to define what you want from your storage in terms of speed/reliability/complexity. It’s easy if you have money to throw at it, but balancing cheap/fast/reliable has a lot of moving pieces. You may want to just try building out something and making adjustments when you learn what you’d like different.
