for my watercooled build in my Geometric Future M8 Lohan White
iv got a Swiftech MCP50X Exteme & Aquacomputer Airplex Radical 4/280 & bitspower-water-tank-z-multi-200-acrylic-version
id like some advice on mounting layout
my rad an fans an case fan layout is as followed the 280mm is in the rear aliened to the bottom two 140 fan
spots in the pull config with a double stack of 140mm noctua 3000rpm in the rear top slot also as intake
the top 120mm spot in also intake with the 3x 120mm fans at the bottom as exhaust
my gpu is mounter horizontally iv yet to find a waterblock for it when i do ill tie it into the loop
my overall question is were an how should i mount the reservoir & pump
an just to clarify the rad an all fans are already installed the way i want
