Advice needed on ups backup's for pc builds/network gear
for powering each of my pc setups ( fyi 1 backup battery per pc ) which of these
would be the best suited for the following builds
build 1 & 2
build 3
an for my network gear (6 items total need backup battery)
would two of these
cover my needs for this gear
D3.1 2.5G Wired Spectrum Advanced Modem
Obihai OBi200 1-Port VoIP Adapter
Panasonic Cordless Phone 4 Handsets - KX-TGF944B (base on battery only)
router - Firewalla Gold Plus: 2.5G
wifi ap EWS276-FIT
EnGenius 2.5Gbps Power Over Ethernet PoE++ Injector | 60W
SODOLA 9 Port 2.5G Smart Web Ethernet Switch,1 10G SFP Slot&8
$100 is insane for that. Consider this:
the poe device iv already got an had for a while along with rest of the network gear , the ups backup’s are the current items to get on which im asking for advice an info on.
Ah sorry I see how the post is organized now.
