Advice needed on mini-itx psu an custom cables
will this psu
power any of these builds
1 . mini-itx beast
2 . mini-itx 6 drive beast
3 . mini-itx 4 drive beast 1 slim odd
4 . mini-itx 6 drive beast 1 ultra slim odd
even with mild oc say 5 - 10% on cpu&ram
an are ther any other part needed to be ordered with it to make it work with the build, i do plan to get custom length cables from cablemods to go with it
does this plug an all the mounting gear in the pix come with the psu,
and will this power brick work correctly with the hdplex
also will these custom cables from cablemods for the silverstone sst-st45stf-g psu
work correctly for the hdflex , and my other alt psu picks like the 400W Power Supply Flex ATX Fully Modular PSU or the FSP400-50FDB
would the 4+4pin cpu plug correctly fit any of these psu’s i cant tell , does the 4+4 conncet to the psu with a 4pin an also i cant tell is the FSP400-50FDB Fully Modular
an as an alt to this psu
No idea if you have found this yet, maybe it is applicable for your use case and maybe not:
Personally I prefer Flex-ATX PSUs over having to deal with bricks and DC-DC. That is personal preference though.
