Im almost done with my new build which will feature a 3900x + 6700xt & 64gb ram
i was going to load with pop os 22.04 lts till i checked back on
the Nobara Linux project an saw all the latest spec an features especially this
an this an a whole lot out of the box newer tweaks then when i first looked
a few things id like to know before choosing are
how much ram does nobara chew for base os an at idle an does it have a swap file an can it be disabled like pop os
does NOBARA have full disk encryption like pop
aside from lutris an proton preinstall can i add the bottles app an does it work better on nobara vs pop
will tuxclocker still install an work for control of amd gpu core,memory,volt an fan controls
i still game about 50% of the time while the other half i do image editing an design work in krita will it run on
nobara the same as pop or better -
i normally add nala an a xanmod custom kernel along with corectrl to my pop os will doing the same in NOBARA cause an
negative issues
