will two of these 1.25G SFP to RJ45 Module, 1000Base-T Copper SFP Ethernet Transceivers work on my EnGenius EWS2910P-FIT 55W Gigabit PoE 8 Port Switch in the 9th & 10th port with 1 to my router & 1 to nas ?
as i have 12 total devices the need to be wired to the FWG router which being able to use the last to ports on the switch will accomplish all this an is worth an extra 37$
some suggest a whole other switch for the cost is what i should do but for me is overkill especially when i did have 2 units each with 8ports an two sfp’s i never used or never knew how to use
so using the last two ports on the fit will do all i need an allow me to keep my network setup tight an uncluttered, if i can set them up as desired
my setup is as followed
isp 2.5gbit modem
FWG router (four port 1-wan 3-lan 3lan=1 to switch, 1 to network printer, 1 to voip phone)
old switch layout same as new but planed with the 9th&10th ports in use
old switch Aumox 8 Port (SG308P) & the new switch EWS2910P-FIT needs to hold my
custom 12tb raidz2 nas
2 wired desk pc’s
2 wired NVIDIA shields
1 wired HP Probook 445 G7 as multi print workstation for
my ANYCUBIC Vyper 3D Printer & Canon CanoScan Lide 300 Scanner
2nd 4tb nas (emergency take an go in case of house fire ,the primary docs)
1 Wireless Access Point (EWS356-FIT) (covers 2 17in laptops vi wifi6 , 2 tablets , 2 smart phones vi wifi5)
1 REOLINK RLK8-410B4-5MP 8CH 5MP Camera System
