Hi everyone,
I need your advice. My wife just got a new Surface 5 from work which she wants to use in her office together with her PC and 2 monitors. Ideally she should be able to just dock her laptop / plug in one cable and be able to use the 2 monitors that are usually connected to the PC.
I have a hard time figuring out how this would to make this work. I have read the KVM guides, but the limited outputs on the PC & Laptop make it hard to know if this use-case would actually work. For my own setup I’m willing to experiment, but for my wife’s setup it should just work.
The hardware:
PC with GTX 970, 1x DP1.2, 1x HDMI 2.0 output
Monitor 1: Asus PG279Q (1440p 165Hz): 1x DP1.2, 1x HDMI 1.4 inputs
Monitor 2: Lenovo G27-20 (1080p 144Hz): 1x DP1.2, 1x HDMI 1.4 inputs
Laptop: Surface 5: 1x USB-C with USB 4.0/Thunderbolt™ 4 output
The PC and Monitor 2 are hand-me-downs from my gaming PC. The mixed DP / HDMI port on the GTX970 has alwas been a PITA to use with dual monitors and is getting on in years.
I was kinda hoping that I could somehow daisy-chain these things together, but that doesn’t seem to be an option.
Then I started looking at the KVM options, but it’s unclear to me if the Surface 5 would be able to drive 2 monitors over the USB-C port.
Closest I could get the config was using the Level 1 Tech Combo USB-C Power Delivery & DisplayPort 1.4 KVM - Dual Monitor.
- The Surface 5 would be connected USB-C to USB-C
- The PC annoyingly would need to be connected with a DP to USB-C combiner AND a HDMI to DP cable.
Would this actually work though?
- Is the one USB-C to USB-C cable enough to power both monitors? The product page implies you need two separate inputs. So I would need to split the USB-C into USB-C + DP somehow?
- All the info on using the USB-C combiner mentions DP1.4. In this case the output and monitor are both DP1.2.
All of this seems like an awful lot of hardware, am I missing a simpler solution?
I can’t do anything about the Surface 5, that’s work issued.
For the PC I could put my RTX3080 in her PC if I really have to which should have ample connections (3x DP1.4a and 3x HDMI 2).
As for the monitors: it would be a shame to get rid of them, but maybe that’s the only way to get a daisy-chain solution … but how would that work nice with the PC?
Advice very welcome. Thanks!
