can i use two EZConvert MB705M2P-B an a Black FD2002 to clone
my current pop os 21.04 with disc encryption on a crucial p1 500gb
to a SK hynix Gold P31 500GB PCIe NVMe Gen3 without issue
an can after be run on the same mobo or a newer one without having to reinstall
or reset anything os wise
Amazon.com: Inateck USB 3.0 to SATA Dual-Bay USB 3.0 Hard Drive Docking Station with Offline Clone Function fit 2.5 and 3.5 inch HDD SSD SATA (SATA I/II/III), Support 2X 8TB and UASP, Black FD2002 : Electronics
ICY DOCKs EZConvert MB705M2P-B is the complete solution to convert an M.2 PCIe NVMe SSD into a standard 2.5 inch U.2 (SFF-8639) NVMe SSD with exact dimensions, connection position and mounting holes. Designed with high compatibility in mind, this...
$45.98
I don’t think the ezconvert changes the NVMe from M.2 to SATA, but instead from M.2 to U.2 which looks more like a SAS connector, with a solid link between data and power connectors, requiring a different dock.
Wendell did a couple videos with U.2 docks that might work, but they needed to be connected to PCIe raid/HBA cards on a desktop.
KenPC
July 5, 2022, 11:22am
3
I would advise hooking up both drives to one computer and booting into a bootable cloning operating system like one from Acronis.
And obviously just make sure the target device is the same if not larger than the source drive.
Theoretically that would work better and cheaper without extra hardware.
