Hi, I am new here (saw few videos on youtube with that funny guy, forgot his name sorry, regarding thread subject) so I decided to open thread here because I need some help.
I currently have Phenom II X4 965BE oc-ed to 4Ghz, msi 760gtx gaming edition, 8gb ram, all that on asus sabertooth 990fx/gen2 r2.0 motherboard.
Recently i was playing few new games like skyrim, tomb raider and ac black flag. While playing I noticed that in some areas my gpu usage drops from 99% to 75% resulting in fps drops from 60 to 40. I did some research and found out that my cpu bottlenecked my gpu in those areas because they are more cpu intensive.This has led me in consideration to upgrade to fx 8350.
Now what would I like to know is will I get better performance with this upgrade I mean I know that I will because this cpu is better but more important question is will I get rid of those bottlenecks in those games and any future games (presuming that they will be fairly optimized) which will allow me to get maximum from my gpu?
will going up to an FX8350 will allways be an upgrade, you realy have the right motherboard for it. so i would allways try that first :) if the game then plays smoothly then you done, if you still keep those fps drops then it could be that the gpu is struggeling also at that point, but 40 fps is still good playable.
Since you have a 990fx yeah by all means grab an 8350. If you're tight for cash grab the 8320, it will OC almost as well as the 8350 (OCing is pretty hit and miss, but it seems like 4.5 is pretty typical OC for the 8320, while I see a lot of 8350s struggling to get past 4.8, so the difference is pretty minor).
No, problem is not in gpu because as I said gpu usage drops to 75%. If the problem is gpu then it those same areas gpu usage would be 99%. 40 fps is still playable but I can notice difference when it drops from 75 to 35-40 fps which is pretty annoying especially if you know that your gpu can max out game with providing constant 60 fps.
All I need to know is does fx 8350 is strong enough to eliminate those bottlenecks?
Skyrim can be pretty hard on vram, and tomb raider and assassin's creed are console ports and they're known to have issues like this, they're always badly optimized.
it's the holidays and black friday is today and cyber monday is on monday. I say get the 8350. There will be some create deals and your motherboard supports it. You will get more performance.
Well that means nothing in my country, big sales are only happening for new year and christmas holidays but nonetheless I purchased fx 8350 this morning.
