I’m looking for some help adding plug-ins, specifically VST plug-ins, to FooBar 2000.
I have Goodhertz Can Opener Studio and Mid Side which I previously used on a Mac unfortunately with software that is not available on Windows.
After some searching I found a FooBar plug-in that allows you to add VST plug-ins to FooBar with the only downside being it is not compatible with 64-bit VST files - which those two are, no 32-bit versions available.
Just wondering if anyone in the community knows of a solution for this or another media player that offers this - preferably similar to iTunes or FooBar.
They just make listening to headphones a little more like listening to speakers by introducing crossfeed. They wern’t that cheap but they work so well.
Might need to purchase JRiver Media Center as that does have VST support.
[EDIT: JRiver Media Center is absolutely terrible so that will not be purchased!]
This is closed as it is outside the revived thread guidelines. Feel free to create a fresh topic, or PM me or one of the Leaders if you think this was incorrectly closed. See here for more info.
