Hello, I have successfully passtrough my 2nd RTX now I want to add my new VR headset (Valve Index) but I can’t add more than 3 USB ports. Thanks for your help.
Might be better served passing an entire controller to the guest. If you have a x1 or m.2 slot open, could use it with a riser cable and add-on usb card.
I think I also stumbled over this problem a while ago.
If I remember correctly I solved it by editing the xml file directly with ‘virsh edit’ and adding Ports manually with new Id/bus
Hi, first time comment here.
I had this problem several months ago. The soluction was quite simple. You should add this in your xml file.
In the section usb controller, you have to change model=ich9-uhci3 by model=xhci port=#want
See the photo below.
Wow that’s easy! Thanks for the great tip, and welcome to the forums.
