Achieva Shimian Menu
I've just recieved a Achieva Shimian QH2700-IPMS Lite Edge but can't navigate the menu as it is all in korean.
Does anybody know of a link to an English translation of the manual or is anyone able to guide me through it?
I just got my Monitor Achieva Shimian,
Mine came with DVI and VGA connections (very accessible), full functions on all buttons but took some time to connect and configure the DVI.
 At first I could not get any response using the DVI, other than power on and off, then I had to connect it to the Laptop PC to configure using first the VGA connection - this one worked automatically.I navigated the Menu in Korean doing some trial an error, the first button below the power button gives you the option VGA or DVI, select up/down with second/third button, and confirm selection with first button.
 Then I made the DVI work with the laptop using an additional adapter to HDMI, and finally I connected it to my Mac Mini. But I had to repeat the process.  Total it took me like 10 minutes
Works great with my Asus laptop and Mac mini, using same HDMI adapter.
So, I can only recommend to follow the advice of Tek Syndicate in youtube or at https://teksyndicate.com
  Good luck with you new monitor and enjoy.
