Double check wikipedia, or the SATA org, but from what I remember:
The are supposed to be build with encryption as default.
When you send a “secure erase” and if it is the right status, it throws away the key, and literally couldn’t decode if it wanted to.
Technically you could then get a raw read of each page and decrypt later, but hey ho. It’s better than re-writing to every cell each time
Nope, it’s saying invalid user and password. So I gotta do this from root. Which is perfectly fine. And thanks for the commands. This ought to hopefully fix everything.
Thanks. It doesnt; work like what I expected then. I genuinely thought it would have kept your user records in places like /etc/passwd, but I guess not
Got my home folder re-made. Restarted the machine and I login. Everything seems fine, my folders are where they belong, I transfer all of the data I need from other drives. But something seems off. I look at the hard drive in my file manager and EVERYTHING from the previous partition is there. All my files, everything. I was wondering why it was asking me to replace files while transferring.
All my old aps still have all the settings. and i notice my desktop customizations are back.
I"m confused as hell. What is going on? Everything that was in my home folder before all of this happened is back. And all I did after remaking my user and homefolder, is restart, do some updates, and restart again.
When you delete stuff off of storage it doesn’t write 0s over them, it just marks the blocks as free to use by the file system. So the data was still there if nothing was written over it.
Now how you managed to link back all the inodes is beyond me, especially since I didn’t read what happened coz am lazy
