Wasn't sure where to ask this so if mods see this feel free to move it if in correct location!
About to get my rig built, I just have several of questions for the knowledgeable user base here.
First, Windows 7 or should I jump right in for Windows 8.1?
Secondly, I'm sure it's been asked but I couldn't find it. Is there a list of top programs I should install with my new PC? I've heard of things like Ninite, but is there a list?
Third, Security wise, I have Trend Micro Titanium, is that sufficient for basic web browsing/video gaming?
Windows 8 and 8.1 have an antivirus called windows defender as a part of the OS. For basic web browsing it should be ok but if u dont trust it there are a number of free options out there. I'm running windows defender alone and i have not come in contact with any problems. Logan made a video on what to do with a new laptop. just ignore all the c cleaner stuff cause it is a fresh install of windows, but he does some other things. He goes to a website that has all these common programs, you just check the boxes of the ones you wanna install and it downloads and installs all of them in one package so you dont have to go surfing around and installing the programs individually. Some other things are installing startisback. Logan made a vid of this start menu for windows 8. I use it myself and i can say i highly recommend windows 8.1 with startisback over windows 7. Hope i helped at all. ( ;
