The rabbit hole beckons. This post was really long, so here’s the short version instead:
Context:
- Arch (though Windows doesn’t work well or consistently in this)
- Voyager 104, confirmed to be functional
- Bluetooth 2.0 dongle, suspect but at least mostly functional
Problem:
- Headset defaults to an A2DP (i.e., output only) devices upon connection
- A2DP works fine. It’s not what I need.
- Headset can be switched to an HSP/HFP device, and it seems to work - hiss starts up as expected, etc. But the microphone doesn’t respond in various programs (Discord, Audacity) - or the microphone works fine and the speaker is silent (these issues alternate).
Relevant installed packages (everything is very recent):
- ofono
- pulseaudio
- pulseaudio-alsa
- pulseaudio-modules-bt-git
- bluez
- bluez-utils
Relevant default.pa snippet:
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy ag=true auto_switch=1
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
I’ve tried:
- bluez-utils-compat
- using the bluetoothctl instead of the KDE stuff, and vice versa
- adding “headset=ofono” to the second line of the snippet above
- Many instances of changing one variable, running pulseaudio -k, waiting a few moments, and giving it a shot again
I don’t need A2DP at all, and frankly I don’t know why Voyager would include it - the headset is physically mono regardless. But I do need to be able to VC on this machine with this headset, and I suspect that should be entirely doable - but I don’t know what to try next. So, anyone willing to help out?
