Not sure if this would go under this part of the forum but can the Amd A10-6800k APU run dayz? it says I meet minimum requirements but will I be able to play this even on lowest settings?
I'm sure you will be able to run DayZ fine as long as you have fast memory (1600-2166Mhz roughly) to back up the integrated graphics on the APU. Not sure the exact fps you will get, but i'm sure you'll run at least 30+ fps.
