Hi,
I would appreciate some input on system solution/ design. This system is well above my expertise and ultimately we will need a professional to head the project. In the interim we are exploring whats possible. There is a healthy budget (< USD100k) for the build.
The key issue is the dataset to be processed is 3.5tb, ideally all in RAM. The client requires onsite processing and will not allow data in the cloud. Ideally, the system can fit in a tower for ease of transport.
My guess at a solution would be a:
- Dual Epyc 7742
- 4tb Ram
- 4x 2tb NVME
I would prefer a white box solution in order to break down the system in 2-4 smaller work stations after the job.
Observations:
- Rack mounted solutions exist but are beasts - not ideal for air travel
- twin epyc 7002 motherboards with 32 dimms (32x128 LRDIMM)?
Any suggestions, including left field ones appreciated!
Cheers
Mark
