It's been a while since last time I posted here, but always kept following the content and the forum.
I have a request for anybody using this gpus, I need a benchmark that no one does the gpu million samples/sec for the dense point cloud generation in agisoft photoscan, this benchmark is way more important to me than gaming benchmarks will determine my holiday buying decision
The steps are the following.
download agisoft photscan demo (if you have it and use it regularly way better)
download the sample data http://www.agisoft.com/downloads/sample-data/ , I'm specially interested in the monument and building sample data
under the tools menu select preferences then go to the opencl tab; select the gpu and set the active cpu core/threads to 0, so we will have the gpu working only.
on the bottom you'll see a tab named console, is besides the one that says photos
start the procesing of the photos, under the workflow menu add photos (make sure to load all of them) the run align photos (set it to low) and the run build dense cloud in high and ultra high ( the later only if you have 16+ gb of ram)
let the reconstructing depth phase run until it finish, the you can cancel the process, and on the console copy and paste here the results. It should look something like this:
Device 1 performance: 588.824 million samples/sec (GeForce GTX 570)
Device 2 performance: 563.746 million samples/sec (GeForce GTX 570)
Total performance: 1152.57 million samples/sec
also temps and (subjective) noise are taken into acount, and if you have any other card don't hesitate topost (a 390x might be considered, for another reasons)
Also please post OS photoscan runs on mac,win and linux, and linux results are the most important to me
Thanks in advance
UPDATE: provisional result tables
gtx 460 stock (monument sample, w 8.1) 277.979 million samples/sec
gtx 460 @ 910 mhz (monument sample, w 8.1) 302.175 million samples/sec
r9 290x @ 1148 mhz (building, w 7, high) 1236.58 million samples/sec
gtx 980 sc acx 2.0 stock (win 10) 1088.03 million samples/sec
r9 fury X (win 10) 1267.63 million samples/sec
r9 290x @ 1148 mhz (monument, w 7, high) 1353.49 million samples/sec
gtx 980 ti stock (monument, windows, high) 1552.84 million samples/sec
gtx 980 ti stock (monument, windows, ultra) 1518.87 million samples/sec
gtx 980 ti stock building, windows, high) 1313.7 million samples/sec
gtx 980 ti stock (building, windows, ultra) 1425.2 million samples/se
r 9 fury unlocked @ 1040mhz (monument, win 10, high) 1456.78 million samples/sec
r 9 fury unlocked @ 1040mhz (monument, win 10, ultra) 1318.94 million samples/sec
r 9 fury unlocked @ 1040mhz (building, win 10, high) 1103.65 million samples/sec
r 9 fury unlocked @ 1040mhz (building, win 10, ultra) 1144.03 million samples/sec
gtx 970 @ 1450mhz(monument, win 8.1, high) 897.446 million samples/sec
gtx 970 @ 1450mhz(building, win 8.1, high) 734.815 million samples/sec
