NOOOOOOOOOOOOOOOO
Blasphemy
And what time wound that be?
When I wake up and itâs the 14th in the US
Really though, wendell has been putting together a video to coincide with the release, so once we tee up on the 14th we will release simultaneously, no fixed exact time though.
tomorrow
Tomorrow is the day!
Please note everyone that a new issue has been discovered, if you have already followed the guides and prepared your virtual machineâs for Looking Glass you will need to change the number of IRQs that ivshmem-server
starts with, originally I stated 1 IRQ, because we really only use one, but there is some strange hang issue with only specifying one.
I have updated the guides to allocate 8 interrupts which will be fine and replicates my development/test environment, so confirmed stable.
The updated command is:
ivshmem-server -p /tmp/ivshmem.pid -S /tmp/ivshmem_socket -l 16M -n 8
I had to use my extra gpu on a different project so I wonât be using this right away.
Still very excited about this coming out.
Well⌠itâs doneâŚ
There is a binary build of the Windows host application on the website so you donât need to mess around with Visual Studio:
Awesome!!! Thanks @gnif - I sure hope this will work on my laptop Will report back any findings/issues.
Does Looking Glass support running headless? Or do we still need to plug an extra monitor?
Iâm trying to use the client, but it appears to only get the same display as SPICE client (which is render by QXL) instead of using the GPU.
Edit: OK, a dummy device is still needed. Not a great news for laptop.
Youâre a legend mate. Looks like I am the first fork.
The first fork of many
hmm?
after typing make
Package gl was not found in the pkg-config search path.
Perhaps you should add the directory containing `gl.pcâ
to the PKG_CONFIG_PATH environment variable
Package âglâ, required by âvirtual:worldâ, not found
Package âgluâ, required by âvirtual:worldâ, not found
gcc -c -g -O3 -std=gnu99 -march=native -Wall -Werror -I./ -IâŚ/common -DDEBUG -ffast-math -fdata-sections -ffunction-sections -DBUILD_VERSION=ââa2-0-g8c2709a3f4ââ -o .build/main.o main.c
In file included from lg-renderers.h:21:0,
from main.c:42:
lg-renderer.h:25:10: fatal error: SDL_ttf.h: No such file or directory
#include <SDL_ttf.h>
Seems I missed a dependency and need to correct SDL path. Make sure you have whatever flavor of libgl*-dev installed for your video card.
Fixed:
no errors now
moving forward
cannot open shm file ivshmem: Permission denied
cannot bind
derp
Please direct all support inquiries to this thread:
That said, try this:
sudo rm /tmp/ivshmem_socket
and run it again. (killing the ivshmem server leaves the socket file)
Small correction to fedoraâs build documentation:
$ dnf install git mesa-libGL-devel mesa-libGLU-devel SDL2-devel SDL2_ttf-devel openssl-devel spice-protocol fontconfig-devel libX11-devel gnu-free-mono-fonts ivshmem-tools
Please submit it as an issue on the github repo
