i just received my new r9 3900x and i’m planning a build using proxmox,
i’m wondering how core allocation works really, lets say i want my main workstation windows vm to have the max amount of cores available to it, and i have a vm that handles video trans codes. can i set a low priority for the trans code vm to only do its thing when the workstation vm isn’t doing much?
the other thing is ill be atempting to passthrough a rx5700 to that windows vm. it seems that 6.2 broke some of the pass through stuff, is there a clear cut guide for 6.2 gpu pass through
I believe you can configure resource pools and cpu shares simliar to how you can on vmware…
Ive never done so, but Ive noticed the fields.
edit::
resource pools arent what I thought they were now that I tried to find the documentation for them…
but i see something called CPU units… so maybe that is what you want
