9800 gtx in sli or 1 9800 gx2 ???
thats a super easy answere, 1 9800 gx2 is like 2 8800gts in sli. 2 9800 gtx's are like 2 9800 gtx's! its an obvious answere, 2 9800 gtx
tri-sli gtx's beat out quad-sli gx2's
:O any GPU is fine
i know tri sli beats quad 9800gx2 but i just dont have the money for that ATM, but thx.
ok, then go with the 2 gtx's
go with 2 gtx's, thats what me and me friend are doing, and honestly two gx2's is not gonna be worth it right now, the tech is too weird
lol 1 9800gtx is fine imagine what u can do with two :)
make sure u get the gtx+. dont wanna end up with one of those old 65nm gpus (like me)
2 9800gtx's beats 1 9800gx2.
2 8800gt beats 1 9800gtx (beats one gtx280 on low resolutions too lol)
It all depends how power hungry you are. Lol. The price of the GX2 went down to like $299 ish. So yeah. Performance wise, two GTX+s will do better most likely. Especially after overclocking. So yeah, if you want to spend 400 total, then go for it =P.
right now 2 9800 gtx = $400+ but 1 9800 gx2= under 300 bucks..right now i'd go 9800 gx2
i personally would sacrifice some fps for a more expandable setup by getting a gtx 260 and overclocking (because they do really well oc'ed) then get a second one down the road. a 260 with a good overclock performs right up there with its big brother.
one overclocked 260 is more than enough for current games and leaves a bunch of room to improve.
yeah i was going to mention ati but figured i'd stick to the question on this one
ohh ya ati's def worth while but since he mentiond 2 nvidia cards i just figured thats what he wants.
the two 9800 gtx's faster but id perfer the 9800 gx2 , looks cool, is cool, weighs more than a brick, my kinda card and not that much lost performance
[url=http://www.newegg.com/Product/Product.aspx?Item=N82E16814130338]http://www.newegg.com/Product/Product.aspx?Item=N82E16814130338[/url]
not too expensive either, $284
i also want a 9800 gx2 cuz the video review logan did was funny, the Dvi- eye in the evga one lollololololol
yeah 2 9800gtx has been proven to outpreform 1 gx2 however you can have I think 4 of those in sli. which means it has a lot more room to upgrade
A 9800GX2 would cost less than a 2 9800 GTX's.
Definitely go with the two 9800 GTXs. The 9800 GX2 is built like shit and will cook itself to death.
April Fools
