Budget:
- Budget is not a design constraint for this build.
- Australia, though could import from overseas if necessary.
Requirements:
- Gaming: Maximum settings. > 60 FPS on 4K displays (if that is possible).
- Work: MATLAB, Quartus II, AutoCAD, E-CAD, Labview, Electronic Workbench... Mostly computer-aided design for engineering.
Design (tower):
- Motherboard: ASUS Rampage IV Extreme* - $535
- Processor: Intel Core i7 4930K* - $675
- Graphics: EVGA GeForce GTX 780 Classified 3 GB × 2 (dual SLI) - $1800
- Memory: Kingston HyperX Beast 8 GB 2133 MHz × 4 - $405
- Primary Drive: Corsair Neutron GTX 240 GB × 2 (480 GB in Raid 0) - $570
- Storage Drive: Corsair Neutron GTX 480 GB × 4 (1920 GB in Raid 10) - $2400
- Power: Corsair AX1200i Platinum 1200W - $415
- Chassis: Thermaltake Level 10 GT LCS 2.0 - $415
- Sound: Creative Sound Blaster ZxR - $290
- Network: ASUS PCE-AC68 - $140
Design (cooling):
- Pump: XSPC D5 Vario - $100
- Reservoir: XSPC D5 Photon 170 mm - $170
- Radiator: Alphacool NexXxos Monsta 240 mm - $90
- Processor Waterblock: EK Supremacy Elite - $155
- Graphics Waterblock: EK Full Cover 780 Classy - $180
- Tubing: PrimoChill PrimoFlex Advanced LRT Black - $35
- Fittings: Monsoon Free Center Compression Fittings × 6 - $40
- Fans: Corsair Air Series SP120 Quiet Edition × 6 - $150
- Coolant: XSPC EC6 UV Clear - $20
Total Cost:
- AUD$ 8585 + shipping.
Comments:
- *The motherboard and processor will actually be X99 components when they are released (just wrote them in for reference now).
- Not interested in a dual Xeon + dual Quadro workstation build because gaming is not optimised for these components from what I have heard (unless gaming on a workstation build is better than the aforementioned one).
- Not sure whether dual superclocked Titans are better than dual classified 780s?
- No experience in water cooling, so still unsure of dimensions. I also do not know how the graphics waterblock fits into the SLI configuration. Would I buy two backplates and fit them onto the two cards, then fit the waterblock in-between?
- Am open to any suggestions, improvements or comments on foreseeable issues such incompatibility or poor choice in parts. I welcome criticism :D
