$870 Gaming/School/Work PC
I have a new PC build and I have the casing already but I need to know if there is anything I need to upgrade or if i can downgrade to knock a few bucks off. I play Minecraft, online games, ncaa football, and a few fighting games. I use Microsoft office frequently, and I watch plenty of YouTube and stream Netflix and Spotify. I listen and download music very often. Open to suggestions. Thanks in advance.
http://pcpartpicker.com/p/CXjQ
Here's a build that is better value. http://pcpartpicker.com/p/DOWa You don't need a CPU Cooler, and with Windows 7 and a WiFi card, you're looking at an 850 dollar machine (:
From all the test that i have seen the radeon 7870 2GB rapes the 660 2GB? I've already ordered a case it is in my home now. I want windows 8. The motherboard you have chosen doesnt have very many usb 3.0 ports. Is it better to get modular or non modular PSU? Is Seagate better than Western Digital.
I have made some changes to mine, for your build had me thinking!! You did make some great suggestions, especially on the GPU and RAM. I don't need a WiFi adapter because i'm using a LAN connection.
http://pcpartpicker.com/p/DPHI
