$850 pc build, whats the best?
so I was wondering i think im going to sell my computer soon to get a better one and if i sold it and my other pcs i would have $ 850 so i was wondering what is the best performing pc for $850
logan has some build videos to assist you. Check them out
yes yes ive watched them but i wanted to get other opions on this matter
What is the purpose of this build?
Do you need other periphirals( mouse, monitor)?
Do you have an OS?
Do you plan on an OC?
o right i should have specifed that, gaming mainly i have an os i have monitors mouse keybourd, all i need is pyhical the parts for the actual pc its self
oops and i might oc in the future
Well worth the extra $20.
Then in the future, pick up a CM Hyper 212 Evo or CM TPC 812 or Noctua NH-D14 for an OC
 thanks for the build i will take that into consideration
http://pcpartpicker.com/p/se00
Thats what i reccomend, for gaming you only need a 2GB card and i think intels are always better for gaming(MY OPINION)
REMEMBER, the CPU is the brains of your computer, for this budget i would focus on that a little more.
Hope this helps!
yes intels are better for for the cheapskate i mean buget minded person i am i tend not to go intel
also i just thought of it which case with out any modding will be able to hold the maxximum amout of rads and and at least one layer of fans
Of course a CPU is important, but a GPU is more so in a gaming build. The FPS difference between a 6300 and 3570K can be anywhere from 0-6 FPS in favor of the i5 (with the same card), but since the build I suggested has a 7970 instead of a 7870, the 6300 will whiz past the i5.
And yes I know that 2GB is more than enough for gaming, but I put that in there just because it can fit and for future proofing. Especially since nowadays we are starting to make 2K HD the industry standard
