Hello, so I am planning to build a PC for Gaming, and also recording and redering videos, and I was wondering, which would do the better job for it. If it matters, I do plan to overclock a little bit, nothing crazy. And also if needed, the other components will be:
Ram: 16 GB (2x8gb)
GPU: HIS 7870
PSU : RoseWill 600 watt
Mobo: I have two decent one's selected for either processor
Because you plan on doing video rendering would you not be better to be using an Nvidia card? I believe they are better for video rendering. With that being said then I would go for the Intel build. Others please step in and correct me if I am wrong.
8350 for video editing. If your editing software is sony vegas, radeon is completely fine. If it's like after effects or other adobe product. definately nvidia, a 660ti or 670 will do you well
OK, so it is dependent upon the software you are using that will have you go towards the Nvidia card. Good to know the proper answer. Thanks as always.
It's got more power, allowing you to overclock and possibly add another GPU in the future if you'd wish to upgrade, a good brand, 80+ and it's modular, making your case neater.
I know there are only a few companies that actually manufacture power supplies. Everyone puts there specs they want to the manufacturer and they make the model and stick whoever’s name on the power supply. Anyone knows who actually produces Rosewill’s power supplies or do they actually make their own?
