80mm Fans for FT03
Unfortunately I cannot fit 2 780Ti's in the Silverstone FT03 without removing the 120mm fan, which means I need some 80mm fans. They need to be able to provide enough airflow with another 120mm for 2 780Ti blower cards and a push/pull H80i in the FT03. I just don't want 2 vacuum cleaners in my case. So probably a max dBA of 40 preferred less than 35 but I can sacrifice that for the airflow.
Example:
Those on the bottom.
I just bought four of these and I really like them.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835226034
They come with rubber mounts and they really help. They can be plugged in with either molex or a three pin connector. They have a really good noise to CFM ratio. Sometimes with noise, it is more about the frequency of the noise than the loudness. I've had fans that are technically quieter, but the frequency of noise they produced made them seem louder. I originally ordered these.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999199
I would steer clear of them. They produce that higher frequency I was talking about and they don't move as much air as they claim. Even though their claimed dBA is lower, they seemed louder than the Silenx fans, and I did a side by side comparison outside the case. Combine that with the rubber mounts for the Silenx and I felt the Silenx was a clear winner.
Check out;
http://www.noctua.at/main.php?show=productview&products_id=9&lng=en
or
http://www.noctua.at/main.php?show=productview&products_id=45&lng=en
Move a lot of air for the size.
Expensive and ugly... yet impressive nonetheless.
