I have been running an ASUS 7970 Direct CU II Top in my computer for some time now and recently purchased a second one to run in crossfire however when running in crossfire I am unable to run most games; for example if I star Arma 3 it gets to the Bohemia logo and then the computer just freezes (can't alt+tab, can't Ctrl+Alt+Del or ALT F4 I just have to do a hard reset)
But here's the weird thing:
>I can run a heaven benchmark with no problem >I can run 3D Mark with no problem >When I first bought it I played a whole mission of BF4 without any problems
What I've Tried:
>Scrubbing my PC of GPU drivers then reinstalling >Checked my power connections to PSU
I have no clue what to do so any suggestions would be much appreciated.
My system specs:
Motherboard: Asus M5A97 LE R2.0 CPU: AMD FX-8350 @ 4GHz (With a H60 watercooling) RAM: ADATA XPG 2133MHz 8GB GPU(s): Asus 7970 Direct CU II Top (X2) PSU: OCZ ZT series 750W single rail 80+ Bronze
Running crossfire on a X16 X4 set up on that cheap mobo dosent help (i'd be checking those unheatsinked VRM's on your mobo with 2 cards running in there heating everything up)
I have the non LE version of that mobo with a pair of 7950s. It gave me lots of trouble at first and it turned out I had to disable ULPS, google up that and give it a try if you haven't yet. I bet those two triple slot cards look very beefy side by side. Good luck.
Thanks for all the help; I've had to send my PSU off for RMA because it's rattling but when it is back I'll try some of your solutions. I tried changing the crossfire bridge and the ULPS settings and some games worked but not ARMA 3 or Far Cry 3 (both hang on launch and cause the PC to freeze) and in the games that worked their were major graphics glitches (lines across the screen but only in full screen) hopefully by the time my PSU is back the new AMD drivers will be out and hopefully that will help.
