I finally replaced the bitspower fittings as the other fittings arrived. I accidently ordered the large plugs rather than the micro ones so I couldn’t replace the silver plugs.
Just a note the rear facing fan should probably face in, as its going to fight the air for that other top facing fan and reduce cooling as that fan wont get as much air.
I have it their as with previous boards I used, the 10gb nic would overheat as the heatsink would get too warm with low airflow over it, with setting the fans low its better having more over fans pulling air off the heatsink.
I upgrade the GPU to a 7900XTX. Going AMD for the first time in years. Between the Nvidia tax and the 12 pin cable issues, I figured it was time to switch. I was pleasantly surprised how good the gpu drivers are now.
I also replaced all the drives with a 2TB Seagate 530 for the OS, 4TB Seagate 530 for game and a 1TB SN850 for data.
