I’ve finally put together the 7950X system I’ve been waiting on parts for the past few weeks. It’s an MSI PRO X670-P system. I decided this time I didn’t want anything fancy - no ARGB! - and figured the PRO mobo would be fine.
Tonight I bench-tested it with the CPU, cooler (NH-D15) and M.2 drives installed. It has a Seasonic 850W PSU.
So, it doesn’t boot. Or rather it did, once, after a few non-booting attempts, and after I’d plugged in the MSI RX 6800 GPU. It reported that it had detected a new CPU then shortly thereafter switched itself off. I’ve not been able to get it to boot into the BIOS since.
The “EZ Debug” LEDs - which are pretty useless IMHO (the light indicates a failure in the device or it not being available) - light up the CPU and DRAM indicators on boot but then go out some time after - a few tens of seconds. I figure since the lights aren’t stuck on that the system actually finds the CPU and DRAM. It did once anyway. The GPU and Boot lights never come on.
After many attempts to make the PC do something again I’ve tried resetting the CMOS by removing the battery and waiting 5+ minutes; I’ve removed the M.2 drives (except the one I can’t reach yet under the cooler) and the DRAM. When I removed the DRAM the DRAM EZ Debug light came on and stayed on. I put one stick back (it had 2 x 32GB Corsair Vengeance DDR5) and the light came on but then went off as usually happens. I’ve also swapped the Radeon RX 6800 for a GeForce RTX 3050 from an i9-12900 system that was working fine until I pulled the GPU out of it. Still no go - monitor says no HDMI signal, same if it’s plugged into the 6800 or into the HDMI out from the mobo that I believe the 7950X is powering. I tried HDMI and DP on the mobo, 6800, and 3050. I even tried a different monitor just in case. No difference with all those combos.
It looks like someone else had a problem getting an MSI MEG ACE and 4090 GPU booting. This feels similar although my mobo is much more rudimentary with less sophisticated POST codes (i.e. none, just the mysterious “EZ” LEDs). And I did get to the BIOS at least once before it went dark. It feels like a mobo problem, or the CPU. I don’t have another 7000-series CPU to swap with.
I’ve been googling of course, and alternately smacking my head against the table.
I put together a couple of MSI builds this year - a 5950X and i9-12900. Those builds went flawlessly so I’m a bit perturbed by having a non-booting system in bench test.
Thanks for any thoughts, pointers, etc.
