Which should I buy 7950 or a 760?
Based on game benchmarking
Overclocking potential
Power consumption
Idle/Max Temperature
Brand
Power consumption
Brand
I also prefer the Radeon 7950, it will also be compatible with Mantle when it comes out. Just make sure that you get an aftermarket cooler on it.
what kind?
HIS and ASUS are good. Maybe MSI
Vapor-X
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150671&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202007&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Either would do nicely, although if you are feeling plush, you could spring for one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127734
Yup I believe that there is one msi at my local microcenter store for $250.
It's worth it if it has their Twin Frozer cooler on it.
yup
Of the ones on newegg right now the HIS is the only one id getting and they are all getting pretty close 280x pricing. if you can get a nice msi one a microcenter for 250 that could be worth it.
Yea it would be totally worth it and stuff, there's also a one that's opened box for $211. I'm not totally sure about that one though.
