7870 really low hash rate for Doge Coins
Right so i wanted to get into some sort of cyrptocurrency and i chose dogecoins because well, i like getting allot of coins, even if they arn't worth allot. i followed this tutorial to get my GPU mining http://doge.yottabyte.nu/ and i have the config file exactly as it says, and i am running CGminer 3.7.2 it works, it does hashes... but not allot...
I am getting like 20Kh/s which is pathetic considering my laptop CPU and pretty much do that..
If anyone can help me it would be great. i am getting no hardware errors, the gpu is clocked at a stable overclock. and it is barley using my CPU or RAM so it isnt that...
Go get GuiMiner, input your pool settings and use the default settings for your card. See if the hash rates improve. Tweak from there after it is working.
do --shaders 1280 --intensity 18
Make a batch file to run your miner and find the correct settings for your card.
intensity too high maybe? on my 7850 i get 386 (voltage locked card) with i 18 but if i push it to 19 or 20 it goes down
Several suggestions for you:
1) Get CGWatcher, it's free, it's awesome, it does cool things like monitor and show graphs, well worth a try.
2) Overclock your card.  Download MSI Afterburner and mess around with some settings.  I have an ASUS 7870 and I get nearly 400KHs.  I am overclocked as follows
Core voltage: 988
Power limit: +0
Core Clock: 925
Memory Clock: 1375
You can push the settings around a little bit, see what it does for you, every card is different.
Here are my settings from CGWatcher, this is what you would put in the miner argument.
--scrypt -u *WORKERNAME* -p *PASSWORD* -o *STRATUM URL* --gpu-platform 0 -d 0 -w 256 -v 1 -I 20 -g 1 -l 1 -T --shaders 1280 --lookup-gap 2 --thread-concurrency 11200
+1 for supercool.ninja.3's suggestions. Those look like solid settings. I did notice that increasing the power limit by %20 (either in afterburner or use --gpu-powertune 20) did substantially increase my hash rate.
Happy Mining!
Just gave that a shot for kicks, didn't seem to do much for me, but then again I'm already hashing at nearly the limits of the card so I didn't expect much.
