OK so i have a 7850, i got it back in mid april and installed the drivers then. I think it might be the drivers, cuz there are probably new ones. But just to make sure, i am getting 13 fps on arma 3 with all the settings on standard or low. I know for sure it is not the server.
My PC:
phenom iix4 965 be
vengeance 8gb 1333mhz
sapphire 7850
MSI mobo
CX 500w
1tb HDD
OK so are the drivers the problem? If so can u please link me to the right drivers becuz i have tried finding them but have failed. Thanks!
read that alot of people just cant get a decent FPS in multiplayer arma 3, even folks with i7 3rd gen and 600 series gpus only get 15-20 fps etc on low.
Probably just something to do with the netcode/server client thats messing it up but the posts ive seen everyone from phenom users to ivybridge users have rubbish fps regardless of settings.
arma does not run the best on phenoms for what ever reason and the other reason is arma 3 kind of runs like crap at the moment. Look up how to optimize your settings to get the best fps because it is kind ok touchy to get the perfect settings. Arma 2 oa will run much better that is what I am playing until they fix arma 3 servers so you can get playable frame rates.
