Currently using 10850k and rtx 4090 build which I’m going to give to my gf and swap my rtx 3080 in there. I ordered 7800x3d and 2x32gb cl 30 6000 ram, and Gigabyte x670 aorus elite ax, Wendell reviewed that motherboard and said one of the m.2 slots makes gpu run at x8 speed, which m.2 slot is that? Also any other stuff I should know about ryzen? This is my first amd system since like 2004 so don’t know what software from amd or 3rd party I should check out or any tips and tricks to get the most out of 7800x3d?
I just watched his video and he was talking about the b650e aorus master when he talked about the gpu speed, also nothing in the block diagram you linked show a reduced bandwidth for the gpu no matter the m2 configuration.
when bandwidth is shared, you can see a switch on the block diagram, see
