750$ Build
Any help I can get with one? It MUST have windows 10 included. I prefer nvidia but if I need to go AMD that is fine too but for CPU I need intel.
Edit: I'm in the USA and its for Gaming and streaming. I am fine with AMD GPUs, the CPUs are just getting old and I don't feel like its best to go with AMD anymore, just my opinion.
What country and what are you doing with it?
Any don't you want AMD? In most cases it may be the better option.
USA, Gaming and streaming.
I am fine with AMD GPUs just the CPUs are getting old and I feel like its a better option to go Intel
Currently they're pretty solid for secondary rendering machines or streaming on the cheap, like if you went with an 8320e OC'd you potentially get an SSD or a higher end GPU, but that depends more on workload if that's worth it
PCPartPicker part list: http://pcpartpicker.com/p/twkdBm
Price breakdown by merchant: http://pcpartpicker.com/p/twkdBm/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
Motherboard: Asus H87M-E Micro ATX LGA1150 Motherboard ($73.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($64.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card ($199.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($34.99 @ Micro Center)
Power Supply: Rosewill 750W 80+ Bronze Certified ATX Power Supply ($69.99 @ Amazon)
Total: $736.92
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-12-25 19:58 EST-0500
Why a Xeon? I'm not gonna hardcore stream, just casually. And I need windows btw
It's basically just a locked i7, well I mean I guess you could buy windows, but windows 10 is seemingly a huge pain, should just buy it and then "find" vanilla windows 7
PCPartPicker part list: http://pcpartpicker.com/p/HyLJhM
Price breakdown by merchant: http://pcpartpicker.com/p/HyLJhM/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($164.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($92.99 @ NCIX US)
Total: $751.91
Generated by PCPartPicker 2015-12-25 20:24 EST-0500
I second the build above assuming you're not overclocking, albeit with some minor changes - grab a lower wattage PSU and perhaps 8GB of RAM instead of 16 if need be to get a better case. Cable management in that case is non-existent.
PCPartPicker part list / Price breakdown by merchant
Type|Item|Price
CPU | Intel Core i5-6500 3.2GHz Quad-Core Processor | $199.88 @ OutletPC
Motherboard | ASRock B150 PRO4/D3 ATX LGA1151 Motherboard | $79.99 @ SuperBiiz
Memory | G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1866 Memory | $64.99 @ Newegg
Storage | Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive | $65.99 @ SuperBiiz
Video Card | Zotac GeForce GTX 960 4GB Video Card | $199.99 @ Amazon
Case | Raidmax ATX-402WB ATX Mid Tower Case | $38.99 @ SuperBiiz
Power Supply | Raidmax 600W 80+ Bronze Certified ATX Power Supply | $45.90 @ SuperBiiz
Operating System | Microsoft Windows 10 Home OEM (64-bit) | $94.99 @ Adorama
| Prices include shipping, taxes, rebates, and discounts |
| Total | $790.72
| Generated by PCPartPicker 2015-12-27 19:32 EST-0500 |
the 1220 isnt hyper threaded and you are better of going most other cpus. even a cheaper i 5.
Type|Item|Price
Video Card | PowerColor Radeon R9 380 4GB PCS+ Video Card | $199.99 @ Newegg
Operating System | Microsoft Windows 10 Home OEM (64-bit) |** $94.99 **@ Adorama
| Total | $790.72
| Generated by PCPartPicker 2015-12-27 19:42 EST-0500 |
The 1231v3 is.
I edited the post he was talking about.
ahk
yea, dont use seagates. you can get a htiachi off of amazon for around the same price, or a wd blue and get a fraction of the failure rate chance.
The wd blue and other drives are 5400 speed.
https://pcpartpicker.com/part/hitachi-internal-hard-drive-hds723020ala640
https://pcpartpicker.com/part/hitachi-internal-hard-drive-0f10311
oddly no wd around the same price range that are sata 6 7200rpm 2t
Already bought it, oops
Er what
No...
