I plan on making a computer based on the $650 rig featured here
http://teksyndicate.com/videos/build-epic-650-pc-july-2012
this is a few months old so is there anything I should upgrade on the list?
also, where would be the best place to buy parts that ships to australia?
if someone on here can tell me a online site to get parts in australia, I'll build a badass PC list for you
http://www.umart.com.au/newindex2.phtml?bid=6
this seems to be the best place, hopefully you can work with that
idk on shipping
Thanks man I really appreciate it
I just have to ask if theres a reasonable quadcore cpu the I could use instead?
I might be doing video and music editing and from what I understand a quad core cpu may be beneficial
yeah but you'll either have to up your budget or comprimise on some parts like the GPU, either I can do for you tomorrow, as I'm tired and done 15 builds today, fun though
Pretty sure I've got a case sitting around anyway, maybe the money from that should make up for it.
i5 3330 would be a good quad
http://www.anandtech.com/bench/Product/289?vs=363
according to that it nearly doubles rendering capabilities, not so much for games but they get a boost if they use more than 2 cores
