Dear experts,
I’m trying to get win10 single gpu passthrough working with my AMD 6800XT reference card, but for now I’m only getting a black screen (no signal) when I startup my vm. It looks like windows is starting up, because when I try to log into windows, my keyboard lights flash for the numpad (but not sure if that indicates that windows is working).
I have followed the following guide:
My system information:
System:
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=XXX rw amd_iommu=on iommu=pt
video=efifb:off quiet apparmor=1 security=apparmor
resume=UUID=XXX udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4021
date: 08/09/2021
Memory:
RAM: total: 62.71 GiB used: 4.41 GiB (7.0%)
RAM Report:
permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Graphics:
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel bus-ID: 0c:00.0 chip-ID: 1002:73bf class-ID: 0300
Bios options:
- Advanced > CPU Configuration > NX Mode > enabled
- Advanced > CPU Configuration > SVM Mode > enabled
- Advanced > AMD CBS > IOMMU > enabled
- Advanced > PCI Subsystem settings > Above 4g decoding > disabled
- Advanced > PCI Subsystem settings > SR-IOV > disabled
- Boot > CSM (Compatibility Support Module) > Launch CSM > disabled (tried to enabled it, but that didn’t work)
IOMMU groups
IOMMU Group 27:
0c:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] [1002:73bf] (rev c1)
IOMMU Group 28:
0c:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] [1002:ab28]
IOMMU Group 29:
0c:00.2 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:73a6]
IOMMU Group 30:
0c:00.3 Serial bus controller [0c80]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 USB [1002:73a4]
As you can see, my GPU as 4 different groups. Accoording to the Risingprism guide, that shouldn’t matter, quote:
AMD users can have there GPU and AUDIO device in different IOMMU group but that is still fine.
I have changed the hooks folder structure from the Risingprism guide, because I was having the same outcome (no signal), so I tried a different approach (other examples that I saw on the web):
/etc/libvirt/hooks
├── kvm.conf
├── qemu
├── qemu.d
│ └── win10
│ ├── prepare
│ │ └── begin
│ │ └── start.sh
│ └── release
│ └── end
│ └── revert.sh
└── qemu_last_backup
start.sh
#!/bin/bash
set -x
echo "Sart script: $(date)"
# Stop your display manager
systemctl stop sddm.service
echo "Stop sddm.service done!"
# Kill audio
pulse_pid=$(pgrep -u brutalis pulseaudio)
pipewire_pid=$(pgrep -u brutalis pipewire-media)
kill $pulse_pid
kill $pipewire_pid
echo "Audio killed with id: $pulse_pid $pipewire_pid"
# Unbind VTconsoles
echo 0 > /sys/class/vtconsole/vtcon0/bind
echo 0 > /sys/class/vtconsole/vtcon1/bind
echo "Unbind vtconsoles done!"
# Avoid a race condition by wating a couple of seconds
sleep 10
# Unload all drivers drivers
modprobe -r amdgpu
modprobe -r snd_hda_intel
#modprobe -r xhci_hcd
#modprobe -r i2c-designware-pci
echo "Unload gpu drivers done!"
# Unbind the GPU from display driver
virsh nodedev-detach pci_0000_0c_00_0
virsh nodedev-detach pci_0000_0c_00_1
virsh nodedev-detach pci_0000_0c_00_2
virsh nodedev-detach pci_0000_0c_00_3
echo "Unload gpu from display driver done!"
# Load VFIO kernel module
modprobe vfio
modprobe vfio_pci
modprobe vfio_iommu_type1
echo "Load VFIO kernel done!"
echo "End of startup: $(date)"
revert.sh
#!/bin/bash
set -x
echo "Beginning of teardown: $(date)"
# Unload VFIO-PCI Kernel Driver
modprobe -r vfio_pci
modprobe -r vfio_iommu_type1
modprobe -r vfio
echo "Unload VFIO-PCI kernel driver done!"
# Re-bind GPU to our display drivers
virsh nodedev-reattach pci_0000_0c_00_0
virsh nodedev-reattach pci_0000_0c_00_1
virsh nodedev-reattach pci_0000_0c_00_2
virsh nodedev-reattach pci_0000_0c_00_3
echo "Re-bind gpu to display drivers done!"
# Re-bind VTconsoles
echo 1 > /sys/class/vtconsole/vtcon0/bind
echo 1 > /sys/class/vtconsole/vtcon1/bind
echo "Re-bind VTconsole done!"
# Load gpu drivers
modprobe amdgpu
modprobe gpu_sched
modprobe ttm
modprobe drm_kms_helper
modprobe i2c_algo_bit
modprobe drm
modprobe snd_hda_intel
echo "Load gpu drivers done"
# Restart display manager
systemctl start sddm.service
echo "Restart display manager done!"
echo "End of teardown: $(date)"
win10.xml
<domain type="kvm">
<name>win10</name>
<uuid>bd9fd7c1-ef70-4e42-a5f7-136ae7432963</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">16777216</memory>
<currentMemory unit="KiB">16777216</currentMemory>
<vcpu placement="static">16</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-6.1">hvm</type>
<loader readonly="yes" type="rom">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
<boot dev="hd"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
</hyperv>
<vmport state="off"/>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="8" threads="2"/>
<feature policy="require" name="topoext"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2" cache="writeback"/>
<source file="/var/lib/libvirt/images/win10.qcow2"/>
<target dev="vda" bus="virtio"/>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</disk>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/brutalis/Downloads/iso/Win10_21H2_English_x64.iso"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<source file="/home/brutalis/Downloads/iso/virtio-win-0.1.208.iso"/>
<target dev="sdc" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="2"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x16"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<interface type="network">
<mac address="52:54:00:af:14:b0"/>
<source network="default"/>
<model type="e1000e"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<sound model="ich9">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
</sound>
<audio id="1" type="none"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x0c" slot="0x00" function="0x0"/>
</source>
<rom file="/var/lib/libvirt/vbios/amd03012022.rom"/>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0" multifunction="on"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0c" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</hostdev>
<hostdev mode="subsystem" type="usb" managed="yes">
<source>
<vendor id="0x046d"/>
<product id="0xc07d"/>
</source>
<address type="usb" bus="0" port="4"/>
</hostdev>
<source>
<vendor id="0x24f0"/>
<product id="0x0140"/>
</source>
<address type="usb" bus="0" port="5"/>
</hostdev>
<source>
<vendor id="0x1b1c"/>
<product id="0x0a3e"/>
</source>
<address type="usb" bus="0" port="6"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0c" slot="0x00" function="0x2"/>
</source>
<address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x0c" slot="0x00" function="0x3"/>
</source>
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</hostdev>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="2"/>
</redirdev>
<address type="usb" bus="0" port="3"/>
</redirdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
As you can see in the win10.xml I also pass the GPU bios. I have tried a downloaded version from techpowerup.com and I have extracted my own GPU bios with amdvbflash, but with the same outcome.
When I ssh into my machine I don’t notice any errors from the hooks
custom_hooks.log
Sart script: Wed Jan 5 01:11:56 CET 2022
Device pci_0000_0c_00_0 detached
Device pci_0000_0c_00_1 detached
Device pci_0000_0c_00_2 detached
Device pci_0000_0c_00_3 detached
End of startup: Wed Jan 5 01:12:06 CET 2022
Beginning of teardown: Wed Jan 5 01:15:53 CET 2022
Device pci_0000_0c_00_0 re-attached
Device pci_0000_0c_00_1 re-attached
Device pci_0000_0c_00_2 re-attached
Device pci_0000_0c_00_3 re-attached
End of teardown: Wed Jan 5 01:15:56 CET 2022
But I saw something in the win10.log:
audio: Could not init `spice' audio driver
audio: warning: Using timer based audio emulation
I have fixed it with the following statement: <audio id="1" type="none"/>
win10.log
2022-01-05 00:12:06.980+0000: starting up libvirt version: 7.10.0, qemu version: 6.2.0, kernel: 5.15.12-1-MANJARO, hostname: user-pc
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/snapd/snap/bin \
HOME=/var/lib/libvirt/qemu/domain-1-win10 \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-win10/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-win10/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-win10/.config \
/usr/bin/qemu-system-x86_64 \
-name guest=win10,debug-threads=on \
-S \
-object '{"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-1-win10/master-key.aes"}' \
-machine pc-q35-6.1,usb=off,vmport=off,dump-guest-core=off,memory-backend=pc.ram \
-accel kvm \
-cpu host,migratable=on,topoext=on,hv-time=on,hv-relaxed=on,hv-vapic=on,hv-spinlocks=0x1fff \
-bios /usr/share/edk2-ovmf/x64/OVMF_CODE.fd \
-m 16384 \
-object '{"qom-type":"memory-backend-ram","id":"pc.ram","size":17179869184}' \
-overcommit mem-lock=off \
-smp 16,sockets=1,dies=1,cores=8,threads=2 \
-uuid bd9fd7c1-ef70-4e42-a5f7-136ae7432963 \
-display none \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=32,server=on,wait=off \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime,driftfix=slew \
-global kvm-pit.lost_tick_policy=delay \
-no-hpet \
-no-shutdown \
-global ICH9-LPC.disable_s3=1 \
-global ICH9-LPC.disable_s4=1 \
-boot strict=on \
-device '{"driver":"pcie-root-port","port":16,"chassis":1,"id":"pci.1","bus":"pcie.0","multifunction":true,"addr":"0x2"}' \
-device '{"driver":"pcie-root-port","port":17,"chassis":2,"id":"pci.2","bus":"pcie.0","addr":"0x2.0x1"}' \
-device '{"driver":"pcie-root-port","port":18,"chassis":3,"id":"pci.3","bus":"pcie.0","addr":"0x2.0x2"}' \
-device '{"driver":"pcie-root-port","port":19,"chassis":4,"id":"pci.4","bus":"pcie.0","addr":"0x2.0x3"}' \
-device '{"driver":"pcie-root-port","port":20,"chassis":5,"id":"pci.5","bus":"pcie.0","addr":"0x2.0x4"}' \
-device '{"driver":"pcie-root-port","port":21,"chassis":6,"id":"pci.6","bus":"pcie.0","addr":"0x2.0x5"}' \
-device '{"driver":"pcie-root-port","port":22,"chassis":7,"id":"pci.7","bus":"pcie.0","addr":"0x2.0x6"}' \
-device '{"driver":"pcie-root-port","port":8,"chassis":8,"id":"pci.8","bus":"pcie.0","multifunction":true,"addr":"0x1"}' \
-device '{"driver":"pcie-root-port","port":9,"chassis":9,"id":"pci.9","bus":"pcie.0","addr":"0x1.0x1"}' \
-device '{"driver":"qemu-xhci","p2":15,"p3":15,"id":"usb","bus":"pci.2","addr":"0x0"}' \
-device '{"driver":"virtio-serial-pci","id":"virtio-serial0","bus":"pci.3","addr":"0x0"}' \
-blockdev '{"driver":"file","filename":"/var/lib/libvirt/images/win10.qcow2","node-name":"libvirt-3-storage","cache":{"direct":false,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-3-format","read-only":false,"cache":{"direct":false,"no-flush":false},"driver":"qcow2","file":"libvirt-3-storage","backing":null}' \
-device '{"driver":"virtio-blk-pci","bus":"pci.4","addr":"0x0","drive":"libvirt-3-format","id":"virtio-disk0","bootindex":1,"write-cache":"on"}' \
-blockdev '{"driver":"file","filename":"/home/brutalis/Downloads/iso/Win10_21H2_English_x64.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-2-format","read-only":true,"driver":"raw","file":"libvirt-2-storage"}' \
-device '{"driver":"ide-cd","bus":"ide.1","drive":"libvirt-2-format","id":"sata0-0-1"}' \
-blockdev '{"driver":"file","filename":"/home/brutalis/Downloads/iso/virtio-win-0.1.208.iso","node-name":"libvirt-1-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":true,"driver":"raw","file":"libvirt-1-storage"}' \
-device '{"driver":"ide-cd","bus":"ide.2","drive":"libvirt-1-format","id":"sata0-0-2"}' \
-netdev tap,fd=34,id=hostnet0 \
-device '{"driver":"e1000e","netdev":"hostnet0","id":"net0","mac":"52:54:00:af:14:b0","bus":"pci.1","addr":"0x0"}' \
-audiodev '{"id":"audio1","driver":"none"}' \
-device '{"driver":"ich9-intel-hda","id":"sound0","bus":"pcie.0","addr":"0x1b"}' \
-device '{"driver":"hda-duplex","id":"sound0-codec0","bus":"sound0.0","cad":0,"audiodev":"audio1"}' \
-chardev spicevmc,id=charredir0,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir0","id":"redir0","bus":"usb.0","port":"2"}' \
-chardev spicevmc,id=charredir1,name=usbredir \
-device '{"driver":"usb-redir","chardev":"charredir1","id":"redir1","bus":"usb.0","port":"3"}' \
-device '{"driver":"vfio-pci","host":"0000:0c:00.0","id":"hostdev0","bus":"pci.6","multifunction":true,"addr":"0x0","romfile":"/var/lib/libvirt/vbios/amd03012022.rom"}' \
-device '{"driver":"vfio-pci","host":"0000:0c:00.1","id":"hostdev1","bus":"pci.7","addr":"0x0","romfile":"/var/lib/libvirt/vbios/amd03012022.rom"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/007/003","id":"hostdev2","bus":"usb.0","port":"4"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/007/004","id":"hostdev3","bus":"usb.0","port":"5"}' \
-device '{"driver":"usb-host","hostdevice":"/dev/bus/usb/003/002","id":"hostdev4","bus":"usb.0","port":"6"}' \
-device '{"driver":"vfio-pci","host":"0000:0c:00.2","id":"hostdev5","bus":"pci.8","addr":"0x0","romfile":"/var/lib/libvirt/vbios/amd03012022.rom"}' \
-device '{"driver":"vfio-pci","host":"0000:0c:00.3","id":"hostdev6","bus":"pci.9","addr":"0x0","romfile":"/var/lib/libvirt/vbios/amd03012022.rom"}' \
-device '{"driver":"virtio-balloon-pci","id":"balloon0","bus":"pci.5","addr":"0x0"}' \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
2022-01-05T00:15:50.314809Z qemu-system-x86_64: terminating on signal 15 from pid 15492 (/usr/bin/libvirtd)
2022-01-05 00:15:53.193+0000: shutting down, reason=shutdown
I also see that the kernel driver in use is vfio-pci:
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:0e3a]
Kernel driver in use: vfio-pci
Kernel modules: amdgpu
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] [1002:ab28]
Kernel modules: snd_hda_intel
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:73a6]
Kernel modules: xhci_pci
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:0408]
I also tried it to start the start.sh script and sudo virsh start win10 (via ssh and the terminal), but that doesn’t help or giving me an error that I notice atleast.
What do I miss to make this working?! Is it not possible with an AMD 6800XT reference card?
