6300 or 6350
Is there any difference other than a factory overclock on the 6350? If I get the 6300 will I be able to get the same performance as I would with a 6350 once I overclock? Do they both have the same overclocking capability? Thanks
Hey!
There are no big differences between this two Cpu's,6350 is just oc'ed higher then 6300.
Save some money,pick up the AMD FX 6300 and aftermarket cooler and you're ready to go!
Cheers.
+1 only reason you should get the 6350 is that it happens to have a combo that the 6300 doesn't have that makes it cheaper or the same price
Alright I will go with the 6300 then. Thanks
6350 is almost certainly higher binned and will overclock better, not that the 6300 can't match it, but it may not have as much luck overclocking
Depends on the price difference. I would pay a little more for a 6350, because it is the higher binned chip.
So the 6350 is better?
If you can find it for the same price or lower as 6300 then yes.You should definitely pick one up!
There is $20 diffrence in those cpu´s mostly. its all depending on your budget.and which motherboard you plan to go with.. Because the diffrence between the FX6350 and FX8320 is also $20 bucks.
Ya Im just gonna get the 6300 and get a decent overclock on it. Thanks everyone for all the advice/ Help :)
Doesnt the 6350 have more cache too?
I think the 6350 has better power management so it should be able to achieve a better overclock and the difference in price is so small that I'd just go with it.
