what is a cheep motherboard that goes well with the amd athlon 750k cause im thinking of getting that and getting a more expencive videocard? would that be smart
I used the cogar spike case for its small size, the athlon 750k due to the 760k not being in stock and a 120mm air cooler. Same HD7850 as your other builds. I also upped the power supply (now Antec HCG 620w) since I'm not a fan of the CX series from corsair, but you can go cheaper on that if you like but you'll probably end up non-modular if you do. I also went with faster (1866mhz) duel channel ram since that motherboard has 4 slots and it was only $3 more than a 1600mhz duel channel kit ($8 more than cheapest 1333mhz single channel kit). Finally I went to a 7200rpm red series WD HDD since it was cheaper and actually is rated for a higher duty cycle than the blues.
sheep in a cart i love that build only thing is would it still run fine without the fan because it may only be 550 but thats with mail and rebates. Which means i need to have 620$ right away then get 60 back later. So without the fan it would be 600 bucks witch i can do. And with the rebate money i can get the fan?
Not a good deal for gaming. The processor is great but the GPU is weak. A lot of pre-built systems have it backwards like that. If it was an FX-6300 with a 7850/7870, that would be much more worth it.
Another thing to note is that 970 chipset motherboard is not necessarily ideal for the power-hungry 8-core FX CPU. May run into problems with CPU power delivery in the not-so-distant future.
