5950x Curve Optimizer
The beauty of Ryzen Master is that you can use it to test to figure out what settings. If that worked.
But yeah I changed my settings in bios too. What I meant is I’m hoping the new Ryzen Master would be better.
And that it is entirely possible that you need to reduce the offset for low-load stability.
PBO and CO is a waste of time on Ryzen.
You don’t get a lot for the extra voltage you punt in.
When Ryzen first came out, I spent eight months finding out how to configure Ryzen more efficiently, and in the process got more performance out of the CPU.
The fundamental flaw of Ryzen is that the architecture has been bastardized for single core boost performance, and it is not possible for Ryzen to switch from the insane voltage it has to put in for a single core boost down to a voltage commensurate for multicore performance without hard crashing the system.
I can demonstrate that on my 7950X, reproduceable 100% of the time.
The voltage that AMD punts into Ryzen at stock degrades the CPU in a relatively short time (months, not years).
My system runs 24/7 and the fact that I can get more performance out of my Ryzen CPUs at lower power and temps than using PBO with or without CO is a nice bonus.
It’s very easy to do and if you are interested, I can show you how.
I’d be curious what you’re doing “different” here; with my 2700X and 3900X it was extremely easy to set a fixed clock OC that was within spitting distance (or occasionally slightly better) of the single core boost behavior, but on the 5950X I’m now running it’s a little different simply because of how much power 16 cores is capable of sucking down at the sort of “midway” voltages I ran on the Zen+ and Zen2 chips.
To be clear, I can roflstomp all over default settings, and baseline “PBO is on” settings with a very mild all-core setting, but small adjustments to PBO limits make surprising changes; and not necessarily going “up” in limits.
+1 Got a 7950X that’s up 24x7 and its behavior doesn’t match the claims being made above.
Firstly, my only focus is being able to run 24/7, so I benchmark to configure, I don’t configure to benchmark.
Secondly, you should not run your 5950X over 1.3 Volts maximum.
So here is the easy way to do it in the BIOS.
For the maximum CPU clockspeed, you choose the setting “Per CCX” and not CPU (even on a single chiplet Ryzen). The reason for this is that it is the only way I have found to not run at a static clockspeed, but rather a dynamic clockspeed.
The other thing to know is that on every dual Chiplet Ryzen, you will always be able to run CCD0 at a higher clockspeed than CCD1 (generally I have found this to be at least 50 MHz).
For the CPU voltage, you set 1.3 Volts (if you have configured to “Per CCX” then this will not be a static voltage).
You can then set the maximum clockspeed for each CCD (or CCX because for the 5000 series and above they are synonymous). With my 5950X that was 4.675 GHz on CCD0 and 4.625 GHz on CCD1- YMMV
I can run 4.6/4.4 down at <1.200V, but my present PBO/CO setup manages 4500mhz all-core while maintaining ~4900mhz boost on any of the 16 should any one core get hammered by itself.
However, going higher on EDC or TDC creates an instant regression to something closer to 4.3ghz, and full default hangs out in the 4ghz neighborhood. Compared to those, I can see benefit from a manual all-core (especially if the majority of your usage is reliant on all-core performance rather than ST), but it’s basically an even trade between ST and MC benefit/drawback for me.
I’ve had my 7950X running 24/7 for 20 months now, with 5.4 GHz maximum on CCD0 and 5.35 GHz maximum on CCD1.
A very recent 10 minute run of CineBench R23 results in a score of 40,250.
Because I have had two spine operations and have spinal arthritis, I have to keep my room temp at around 30 degrees Celsius, and the hottest my CPU gets during the 10 min run is 81.5 (or a delta of 51.5 degrees) and the maximum CPU power usage is 164 Watts.
For cooling I use an Arctic Liquid Freezer III 360, and it goes without saying that I have not delidded my CPU.
Score after 10 minute run
Highest temp during a 10 minute run
“Single Core Boost” (or, as I call it, “Boast”) on Ryzen is nothing more than Marketdroid/Salescritter bullshit.
It is a fundamental flaw in the Ryzen architecture that AMD should have gotten rid of years ago, simply because of the stupid amount of voltage that has to be punted in to achieve it, damages the CPU in a relatively short time.
In fact, it has been dropped by one class of Ryzen CPUs, namely the X3D CPUs, where all core clockspeed equals single core clockspeed.
As soon as more than one core is engaged you can kiss any kind of boost goodbye, the only thing that remains is the ridiculous amount of voltage that is punted in, simply because the CPU cannot drop voltage low enough to be commensurate with multi-core performance.
I have written two guides (one for all 3rd/4th/5th gen Ryzen on any mobo and one for the 7800X3D on any mobo) and one of those guides is being used internally at AMD.
My focus is on 24/7 stability, because that is how I have run my systems for decades now.
I hope that AMD has given up this lunacy for the 9000 Series of Ryzen, but I will only know that in a couple of weeks when I get my greedy grubby little paws on a 9950X.
If you want to discuss it further, then you can reach me on Discord under the name “michaelnager” with the same avatar as here.
Can you share your two guides? I’m intrigued.
Thank you!
I already posted them on another thread and I just hope I don’t get accused of spamming by posting them here, but here you go
My guide to configuring any 3rd/4th/5th Gen Ryzen on any compatible motherboard:
https://www.reddit.com/r/ryzen/comments/tntrif/definitive_guide_to_configuring_3rd4th_gen_ryzen/
My guide to configuring the 7800X3D:
https://www.reddit.com/r/ryzen/comments/137i5f5/how_to_optimally_configure_the_ryzen_7800x3d/
And not a guide, but documents my experience with my 7950X after around 20 months of 24/7 usage:
https://www.reddit.com/r/ryzen/comments/1cwb46h/7950x_running_247_for_20_months_no_degradation/
Well I just want to say I kicked it up some…
I am now running at negative 24…
wow
I am not unsure if this thing actually works…
Apparently Curve Optimizer has a Cap at 32… I am running Negative.
So Currently as I type I have it set at 30. PBO limits off.
I will test by packaging my UE5 game.
Unreal Engine Always makes unstable machines crash…
Ok well here was a test… I have a dual boot with Win10.
I decided to go into Win10 and it logged in, made it to desktop, and
The moment I went to do something other then O.S.
It crashed and reboot.
Just a note… Currently back in Slackware 15+… no issues… It feels faster too.
Did I get a magical CPU ?
No, this seems to be „a thing“. Instability shows up quicker in windows compared to Linux. Not sure why, but I’ve noticed it too. Maybe background processes, differences in scheduling, idk
But for sure, your machine is not stable and it will show up at some point, also in Linux.
Errors might also be more hidden in Linux. Check dmesg, journals.
After playing for a while with UE5… cause it is the most intense thing I have used
It seems 24 seems to cut it stable.
