So I was playing with Curve Optimizer with a 5950x
-20 so far…
Is that good?
And should I keep pushing it?
Oh Mobo is Asus Tuf X570+
EDIT: 128 GB 3200 ram and running Slackware 15 Current.
-20 so far…
Is that good?
I think I put this in the wrong category.
It is not a GPU
Err it is a CPU lol
fixed ![]()
you need to cycle stress tests to validate your undervolt settings.
the corecycler script on OCN is pretty helpful for this.
Depends. What are your objectives, how was -20 obtained, how is stability being validated, and is this an all core offset or per core?
Corecycler’s distributed through github?
yep that’s the same guy as on OCN.
So, the “trouble” with the curve optimizer is that you can spend an infinite amount of time trying for more optimization, and the gains get progressively smaller.
I’d have to reboot to check, but I think I’ve landed on -12 with mine because it works while being enough difference to be a net positive. Also, PBO limits are kind of interesting and more does not always mean more.
Edit: Yeah, so, my current setup is -12 CO, 220/160/180 PBO limits, 8X PBO multiplier, 2000mhz “maximum” boost override (pretty sure it actually caps at +200 but whatever). Same board as you, half the RAM (16x4 here). I’m also running SoC voltage down in the weeds at 950mv because at lower RAM speed (such as 3200mt/s) it doesn’t seem to need more and the budget goes straight to cores. All I know is it holds 4.5ghz all-core under load and hits single core boosts of 4.9 on all 16, with occasional spikes as high as 5150 on a few cores.
Yup. I had the 5950X I use most at -10 on most of its cores for a while and, though it was stable under stress and never failed under load, there were a couple crashes over several months while idling. Some of the clocks showed +100-200 MHz but benchmarks and power draw stayed the same within the accuracy of the testing I did. I’d hoped for more but these results seem not too surprising as desktop cores already boost to little to no return at stock and I wasn’t lifting PBO limits.
Ended up changing motherboards and, since a moderate offset didn’t appear to provide advantage with the silicon I’ve got, haven’t bothered putting the core offsets back on. Since mostly -10 wasn’t entirely stable it hasn’t seemed worth trying for lower. Though, different mobo manufacturer, different BIOS, maybe it’d be worth it.
At some point I’d like to look into taking a few watts off the idle by lowering Vsoc but it hasn’t been a priority.
With both the Asus boards I’ve tried, vSoC defaults to 1.1V once you enable an XMP profile. This is “good” in that it seems to work every time, but being SoC power it’s a continuous heat source. It’s actually enough of a difference that true “default” settings (including RAM at JEDEC) posts considerably higher single-core benchmark results. I’ve run as low as 900mv at 3200mt/s without issue, but I like having settings that I know I don’t have to troubleshoot unless I feel like toying with things more, so 950 is where I landed. Still somewhere around a 15% cut in system-on power, so…
Haven’t inventoried our boards to see what they do. FWIW, the ASRock and MSI I just checked, both with DDR4-3200 XMPs, are 0.992 and 0.994 V. The Asus at 3400’s 1.084.
Strange but true…
I have been using Unreal Engine 5.** for stress testing
It runs the processor all cores all threads at max…
I got your link I will check that download out.
Thank you.
I just did a reboot to double check my ancient brains ability to recall…
Ya I am sitting at -20 …Soc volt at 1
I turn off PBO limits.
Ram voltage is at 1.35
Everything else is set to auto.
I download this and see the read.me and I always do.
I saw Power Shell and thought windows???
XXX.bat is windows…
I use Slackware15++
There seems some basic confusion here. Windows started moving off batch files 20 years ago and PowerShell’s been cross platform since 2018. Prime95, which is what CoreCycler’s built on, is also cross platform.
It’s not my impression CoreCycler’s gets much use on Linux, consistent with the roughly 19:1 ratio of Windows:Linux installations, but it does appear you not noticed Run CoreCycler.bat just calls script-corecycler.ps1.
Learn something new every day.
While powershell is available on linux (for some reason), you are pretty sure wasting time trying to run corecycler there.
That code does not look like to be designed with portability in mind, there are fuctions explicitly using win32 api calling command host.
Good luck running that ![]()
But if you do get it to run, prepare a drink for celebration, for you would have probably doubled the current amount of powershell on linux users.
If Wine can make malware work on Linux, then maybe? ![]()
Maybe. I’m unsure of the state of CIM support via OpenLMI on Linux (and #29 is superficial) but, skimming through the 9500 lines of script-corecycler.ps1, Wine seems likely to cover all the p/invokes. Just porting to Linux doesn’t look all that involved, though it’d definitely be an effort. AIDA64’s Linux support’s limited, so those cases might be tough, but y-cruncher looks feasible.
From what I understand, just because it’s stable in a stress test (even if it’s a per core/thread stress test) does not mean it’s stable when it’s not stressed. That was my main frustration with Curve Optimiser.
I think this is why the new Curve Shaper exists. I hope there are automated ways to reliably shape the curve in the future. Not convinced the Auto-whatevers in Ryzen Master for Curve Optimiser is reliable enough…
(not a 5950X user, 7950X instead, but I believe this applies to Curve Optimizer in general)
I don’t use ryen master
I actually do everything in the bios/uefi
