I see a ton of videos about undervolting this CPU, but I get the impression most are more so just throwing crap at the wall, as it were.
From my understanding, limiting voltage limits current as well (and thus lowers heat). However since we can control current with PBO2, why not just limit current, and leave voltage alone for stability?
Similarly, why would we limit PPT (watts) when both voltage and amps are being manually limited? I asked because some of the numbers people have thrown together aren’t really compatible such as a 1.05v X 115A EDC with a 110w PPT
I recently got my hands on a 5800X3D for my daily machine and tuned it this way:
PPT @ 114W
TDC @ 78A
EDC @ 115A
PBO -26 on C0, -28 on C1, -29 on C3 and eveything else -30 (I’m recalling off the top of my head so if you want me to be sure let me know so I’ll check in BIOS).
With HWiNFO64 open running CB24 multicore I’m not seeing the CPU bumping into the power limits I’ve set. But I’m cooling it with a Noctua NH-L9x65 cooler in an SFF system so it’s struggling to keep the thing cool. It reaches 88°C during a run but it’s not throttling too much. My MC score is 879 which is a bit short of properly cooled systems but not too far off.
My reason is cooling, which leads to better opportunistic boosting by the CPU. Apparently even when running a big enough cooler for this CPU the temperatures gains allow the CPU to boost at it’s peak forever, while keeping the cache cooler. Remember that cores on this CPU have a “blanket” in the form of the 3D V-cache that reduces the effectiveness of thermal transfer into the heat spreader. So, in the end, changin PPT, EDC and TDC is more of an hard limit for my system, nothing more.
More in general to reduce temperatures and power consumption you’ll need to take PPT, TDC and EDC way down, reducing significantly the performances of the chip. Meanwhile if you set the right PBO negative offset you’ll reduce temperatures and power consumption without taking a hit to performance (sometimes even increasing them).
PBO is a voltage/frequency table. If you move it down “vertically” the CPU will use less voltage to boost at the same frequency. The hard cap is on the maximum voltage so you can undervolt as much as the CPU allows you to.
EDC, PPT and TDC squash the curve horizontally because you’re not reducing the voltage at a given frequency but you’re limiting the current to the CPU at the same voltage, which results in lower clocks.
