You use aint in wrong way
Americans are rubbing off on you
In this case does not is still preferred even in slang.
Have little patience…5000 series amd is about to drop. It will either gain you better performance for your dollar or drive prices down of 3000 series amd cpus. In either case I recommend an x570 mb and most in the mid tier are okay.
You should know better than to expect cutting edge tech and linux. At least as far as in common use desktop world.
In terms of memory G.skill Tridend Z kits, 3600mhz / 3800mhz CL16 or CL18.
Should basically be fine.
We don’t really know yet how far the new upcoming cpu’s will go on IF of course.
But 3600mhz CL16 should be a fairly safe bet.
Another good brand would be Cruicial Balistix with micron-e die.
Those also seem to play fairly nice with Ryzen.
Going either 3800x or 5800x. I’m assuming that there are “fewer” bugs as it is getting EOL and will only get better, seems like the linux thing to do.
The bugs in 3000 have been worked out. Can’t know about 5000 series.
True but the chipsets and ram aren’t changing in the near future
5800x would probably give you a better experience, but my 3900x still has some power management issues with my asus board.
You know if these come with a cooler?
