So whenever you’re ready, and you have another device to communicate from, you’re gonna do basically the same thing as an Ubuntu beta release upgrade sudo do-release-upgrade -d, but we’re gonna do it manually and a bit more aggressive.
So the first thing is gonna be to install tmux and openssh-server:
sudo apt install tmux openssh-server
Next, we’re gonna point our system to the repositories for the newer release.
sed -i'' -e 's/disco/eoan/g' /etc/apt/sources.list /etc/apt/sources.list.d/*
Then you’re gonna launch a tmux session with
tmux
which should give you a fresh shell prompt. It may ask you to choose your style or set a prefix key. Do whatever you like, but try to remember what your prefix-key is. If you don’t know what it is, you can display it with tmux list-keys |grep send-prefix. It’ll be the content of the third column, probably something like C-a or C-b. The capital C stands for the control key.
Then you’re gonna run
sudo apt update && sudo aptitude dist-upgrade
(I like to use aptitude first because it has a gentler dependency resolver for dist-upgrade.) Updates will chug along, and you will be prompted about using old or new config files a few times. Unless you manually edited the config in question, choose the newer one.
If anything gets stuck, or you see any errors, let me know and we’ll solve them together. If nothing does come up, show me the output of apt list --upgradeable. Those will be the last components we need to upgrade to finish the release upgrade, which we’ll handle similarly as above but with sudo apt full-upgrade, and possibly some other manual adjustments.
I’m not quite good to go yet, though: mesa haven’t done the trick. I tried running dist-upgrade and found that the navi10 firmware files were missing. Trying to install amdgpu does not fix this, and produces more errors. If I try rebooting now, I have a feeling it won’t work without the navi10 files, but at least the screen didn’t black out on installation this time, so that’s progress, right?
